pagu
#1 Posted : Tuesday, January 31, 2017 12:31:02 PM(UTC)
pagu
Hello dear team,
i have download the vmix trial, and want buy it.
Only one little info, i use only the streaming and the little call for create a picture of stream image by 8080 Snapshot every 5 min,
and my resolution streaming is 864*486.
i have to buy Basic HD, right?
Thank you
#2 Posted : Tuesday, January 31, 2017 1:59:05 PM(UTC)
@ pagu
I am not familiar with the "little call for create a picture of stream image by 8080 Snapshot every 5 min" (or how to do that and why) but if you are not tied to the 864*486 resolution, I would suggest trying the FREE version first to see if it meets your needs and upgrade from there if necessary.
If that "call" requires a script, then perhaps you are looking at acquiring vMix 4K or Pro.
Feature Comparison List:
http://www.vmix.com/purchase/
Both the vVix Basic and Basic HD have considerable limitations compared to other Editions, but if your needs are simple, either one just might fit the bill...
#3 Posted : Tuesday, January 31, 2017 2:34:00 PM(UTC)
Using the "snapshot" shortcut could be used , maybe even with external little timer script to get an image each time (if i correctly understand the request)
with the pro or 4k version one could use the vMix scripting instead of external triggering
kjones9999
#4 Posted : Thursday, February 2, 2017 12:05:14 AM(UTC)
kjones9999
the program sharex could automate the screenshot process.
