Audio input (from input device) not showing in mixer
Joined: 10/5/2010(UTC) Posts: 21 Location: Netherlands
Hi, me again.. :)
So I'm selecting my Intensity Pro as input device and I check the 'audio'-box, hoping to be able to hear the sound from my camera (which is of course connected to my Intensity Pro). No sound though and when I open the mixer there's nothing there (no vu-meters in neither of the tabs).
When I add an audio device as input (so it shows up in the Input List) I do see a vu-meter in the mixer, but no sound is coming through.
Anyone an idea what could be going wrong?
Thanks! Albrecht
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
The audio checkbox is only for DV and HDV sources. To use the audio from the Intensity Pro it needs to be added seperately via the Add New Input, Audio tab.
I'm seeing the same thing. I have a Intensity Pro and I'm unable to get audio from it. I'm adding it as a separate Audio Input (Decklink Audio Capture, 48000 16 Bit 1 or 2 Channels), and I get no sound. If I go into the mixer, I see a Decklink Audio VU mixer with levels at zero and not moving.
I get audio over Decklink Audio Capture in Adobe Flash Media Live Encoder, so it's not an issue with my hardware setup.
This issue is currently being investigated, will let you know what I find.
Martin vMix
I managed to get it to (sort of) work -- I had to add a video capture input as well, and then the audio started playing from the audio input. Very strange.
Sadly the audio is sort of crackly/clippy and delayed by about 4 seconds, so it's not really usable, and I'm left looking into alternate audio options.
It looks like the DeckLink audio device does not work independently of the video capture. I am testing the option of linking the audio device with the capture input and so far the audio appears to be in sync and without any crackling.
I will release a test version once the testing is complete.
Martin vMix
The following test version is now available: http://www.vmix.com.au/d...oad/vmix2011v10testb.exeThis version includes the option to specify an audio device when adding a video capture device. This allows the grouping of DeckLink audio and video devices which is required for audio sync with the latest drivers. Let me know how it goes. Regards, Martin vMix
Rank: Guest
Groups: Guests
hi martin, i tested this new v10testb with the *.mp4 file i sent you. now the audio is working fine after loop but the video goes black after first time played. thks for the progress, regards... melody www.espiritosanto.cc
Hi Melody,
The new test version does not have any changes to how mp4 files are played. I would suggest uninstalling some of the codecs you have and using the built in MP4 decoder in Windows 7.
Rank: Guest
Groups: Guests
thats ok, i`ll try it. in my case, specifically, i can contour this situation and use vmix without problems but to another users it maybe an obstacle. thank you for your attention, regards... melody www.espiritosanto.cc
