Record vs. MultiCorder CPU usage
Joined: 3/28/2016(UTC) Posts: 171   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
So i know the difference between the two, but i wanted to know if there is something behind the scenes that would make multicorder much more resource intensive than recorder?
vMix 18.0.0.61 x64
My test was 1 camera via SDI at 1080p and i set the recorder to the exact same codec as multicorder. So the video recorded had the same frame rate, codec, quality size and everything and the end result looked identical as well. However, if i just run the recorder the cpu is around 3% and if i just run the multicoder it's around 20%
just in case it matters i was using the MagicYUV 4:2:2 codec
i guess i'm just curious why the same recording of the same input is much more intensive on the multicoder than the recorder.
thanks
-king
Thanks: 23 times Was thanked: 10 time(s) in 7 post(s)
I´d also like to know that!?
I'm not sure but I'd say that recorder is taking advantage of GPU's hardware encoder while multicorder cannot as GTX cannot handle more than 2 simultaneous encoding sessions. Just a guess Guillaume
How many inputs can multicoder do depending on my system....i7, 12 gigs ram, 500g ssd, nvidia GTX 10 series board....I just want to know how many inputs....or better yet, what specs will I need to handle 8 HD inputs
Quote:How many inputs can multicoder do depending on my system Only you can answer your own question. It depends on so many things not only the hardware. Just test and find the limits Guillaume
