use an alfa video file as a transition
Rank: Guest
Groups: Guests
hi Martin, can you implement a feature that make possible to use an alfa video file as a transition? the idea is to use something like that: see the 00:16, 01:11 and 09:18 if is possible on that feature, give the option to choose what time of that video the user wishes to make the change of camera. regards, melody
Joined: 1/13/2010(UTC) Posts: 5,304  Location: Gold Coast, Australia Was thanked: 4674 time(s) in 1609 post(s)
These sorts of transition effects cannot be done with an alpha channel video file. To explain why, consider a simple horizontal wipe effect:  This effect requires two channels, the A mask and the B mask. Alpha channel only provides one channel of information.
Rank: Guest
Groups: Guests
so, can you implement a 3 channel transition effect with possibility to choose what do you want(video,image,swf...) to use on each channel? or only choose what do you want to use on 3rd channel?
maybe i`m sugesting by the wrong way, please forgive me about that, but what i mean with this sugestion is that the final result in vmix to be a transition effect like you can find on posted youtube video, or something like that.
