kgoodyer
#1 Posted : Friday, January 20, 2017 1:44:32 AM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Hiya
Any chance you could look at add the ability to add the ability to set "Stinger Input" and "Stinger Cut Point" into the API. I was quiet surprised not to see it there already, and proberbly the first time I have needed an API function that wasn't there. I am sure some people would love to be able to set some of the the other stinger options, but personally I only ever use a cut in my stingers.
Using it for some motor sports and each driver has his own singer, so I need to be able to quickly call up any one of 25 stingers.
Cheers
Keith
Peter B
#2 Posted : Friday, January 20, 2017 2:34:42 AM(UTC)
Peter B
Also having the choice of a mix or cut for the background transition so the stinger graphic doesn't have to go full frame to mask the cut opening up a lot more graphical possibilities.
stevespaw
#3 Posted : Friday, January 20, 2017 8:12:55 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
+1
xaver
#4 Posted : Saturday, March 11, 2017 2:44:40 PM(UTC)
xaver
+1
