Feature Requests
Stinger Inputs and Stinger Cut Point setting Via API
Joined: 6/16/2015(UTC) Posts: 193 ![Man Man](/Themes/yafpro/male.gif) ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Location: Milton Keynes, UK Thanks: 10 times Was thanked: 53 time(s) in 27 post(s)
Hiya
Any chance you could look at add the ability to add the ability to set "Stinger Input" and "Stinger Cut Point" into the API. I was quiet surprised not to see it there already, and proberbly the first time I have needed an API function that wasn't there. I am sure some people would love to be able to set some of the the other stinger options, but personally I only ever use a cut in my stingers.
Using it for some motor sports and each driver has his own singer, so I need to be able to quickly call up any one of 25 stingers.
Cheers
Keith
Joined: 4/14/2013(UTC) Posts: 264 ![Man Man](/Themes/yafpro/male.gif) Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
Also having the choice of a mix or cut for the background transition so the stinger graphic doesn't have to go full frame to mask the cut opening up a lot more graphical possibilities.
Joined: 3/12/2015(UTC) Posts: 482 ![Man Man](/Themes/yafpro/male.gif) Location: Kansas City, MO USA Thanks: 151 times Was thanked: 75 time(s) in 57 post(s)
Joined: 11/11/2016(UTC) Posts: 378 ![Man Man](/Themes/yafpro/male.gif) Location: Europe Thanks: 23 times Was thanked: 38 time(s) in 32 post(s)
Feature Requests
