Feature Requests
Adjust multi view panel size
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
I would like to be able to adjust the size of the panels in multi view. I use PowerPoint for graphics and at times would like for the graphic to occupy most of the view with my webcam input small. Is this possible now? This would work similar to a PIP arrangement.
@ samrikard
If I understand you correctly, I believe you are referring to the Input MultiView feature and not the MultiView Fullscreen Output display. The "MultiView" feature is very a powerful tool in vMix and is very customizable allowing up to 5 Overlay channels (or screens) that can be sized and placed anywhere on the screen. If you are looking to have a dual screen PiP special effect with the PowerPoint Input being larger than the camera Input (I do this often), I would suggest creating a "Blank" or "Colour" Input and add your desired Inputs as Overlay 1 and Overlay 2 in the "MultiView" settings and size each using the "Position" button for each Overlay channel.
Hope that helps some.
Thanks IceStream, sometimes I just need a little direction. Your assistance is greatly appreciated and pointed me to the solution to my issue.
Feature Requests
