samrikard
#1 Posted : Sunday, January 15, 2017 11:15:22 AM(UTC)
samrikard
I would like to be able to adjust the size of the panels in multi view. I use PowerPoint for graphics and at times would like for the graphic to occupy most of the view with my webcam input small. Is this possible now? This would work similar to a PIP arrangement.
#2 Posted : Sunday, January 15, 2017 11:53:04 AM(UTC)
@ samrikard
If I understand you correctly, I believe you are referring to the Input MultiView feature and not the MultiView Fullscreen Output display.
The "MultiView" feature is very a powerful tool in vMix and is very customizable allowing up to 5 Overlay channels (or screens) that can be sized and placed anywhere on the screen.
If you are looking to have a dual screen PiP special effect with the PowerPoint Input being larger than the camera Input (I do this often), I would suggest creating a "Blank" or "Colour" Input and add your desired Inputs as Overlay 1 and Overlay 2 in the "MultiView" settings and size each using the "Position" button for each Overlay channel.
Hope that helps some.
samrikard on 1/15/2017(UTC)
samrikard
#3 Posted : Monday, January 16, 2017 1:21:06 PM(UTC)
samrikard
Thanks IceStream, sometimes I just need a little direction. Your assistance is greatly appreciated and pointed me to the solution to my issue.
