rjmurdock
#1 Posted : Wednesday, January 11, 2017 12:35:17 PM(UTC)
rjmurdock
I've build a vMix system with 6 output capabilities, however, when I try to select a Display output option, I'm only able to select from 4 of those outputs. Granted, those four output are on one graphic card and the first four numbered. I can't see the 5th & 6th monitor outputs to select as a Display out.
Is there anyway for me to have the option to select one of the other two?
#2 Posted : Wednesday, January 11, 2017 1:13:52 PM(UTC)
afaik no
But :
- you can use the external renderers with output video cards (BM Mini Monitor for instance or any supported dard with output capabilities on PCIe or Thunderbolt etc...)
- you can also use NDI outputs to send signals to a 2nd machine with more monitors
