Joined: 11/12/2012(UTC) Posts: 51  Location: Fort Walton Beach, FL USA Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
I've build a vMix system with 6 output capabilities, however, when I try to select a Display output option, I'm only able to select from 4 of those outputs. Granted, those four output are on one graphic card and the first four numbered. I can't see the 5th & 6th monitor outputs to select as a Display out.
Is there anyway for me to have the option to select one of the other two?
afaik no
But : - you can use the external renderers with output video cards (BM Mini Monitor for instance or any supported dard with output capabilities on PCIe or Thunderbolt etc...) - you can also use NDI outputs to send signals to a 2nd machine with more monitors
