Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Hello!
Two questions. 3-4 HD cameras at some point via Thunderbolt
1. nVidia GFT 1060 or 1070 for laptop ? Or perhaps 980M or lower 2. i5-6300HQ or i7-6700HQ for laptop ?
Or any suggestions ?
-Tommi
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi Tommy
Thunderbolt 1, 2, 3 ? With an extension chassis or an AJA box ?
Go i7. Any GTX above 700 series will do the job. Take the best you can afford.
DWAM wrote:Hi Tommy
So i7-6700HQ + 970M would good good ? And in future thunderbolt extension box add. Like this Asus 17,3" ROG Strix GL702VT Win 10 Home 64-bit Intel i7-6700HQ, 2.6 - 3.5 GHz 17,3" IPS Full HD 1920x1080 Anti-Glare NVIDIA GTX 970M, 3GB GDDR5 GB DDR4 2133 MHz 128GB SSD + 1TB HDD WLAN: 802.11ac Bluetooth: 4.1 - HDMI - Mini DisplayPort - 3 x USB 3.0 - 1 x USB 3.1 Type-C - RJ-45 Price 1499e -Tommi
I have a 4 years old Asus ROG G750J with i7 4700HQ, 8G RAM and a GTX770m. Supports easily up to 6 HD sources (from TB, USB and NDI) for streaming and recording.
You should be fine. I'd suggest to replace the 1TB HD by a SSD...
OK, thanks. I made it safe and bought ASUS GL702VM and replaced 2nd HDD to SSD :-)
-tommi
