-TA_
#1 Posted : Sunday, January 8, 2017 1:55:45 PM(UTC)
-TA_
Hello!
Two questions. 3-4 HD cameras at some point via Thunderbolt
1. nVidia GFT 1060 or 1070 for laptop ? Or perhaps 980M or lower
2. i5-6300HQ or i7-6700HQ for laptop ?
Or any suggestions ?
-Tommi
#2 Posted : Sunday, January 8, 2017 2:45:30 PM(UTC)
Hi Tommy
Thunderbolt 1, 2, 3 ? With an extension chassis or an AJA box ?
Go i7. Any GTX above 700 series will do the job. Take the best you can afford.
-TA_
#3 Posted : Sunday, January 8, 2017 3:27:23 PM(UTC)
-TA_
DWAM wrote:
Hi Tommy
So i7-6700HQ + 970M would good good ? And in future thunderbolt extension box add.
Like this
Asus 17,3" ROG Strix GL702VT
Win 10 Home 64-bit
Intel i7-6700HQ, 2.6 - 3.5 GHz
17,3" IPS Full HD 1920x1080 Anti-Glare
NVIDIA GTX 970M, 3GB GDDR5
GB DDR4 2133 MHz
128GB SSD + 1TB HDD
WLAN: 802.11ac
Bluetooth: 4.1
- HDMI
- Mini DisplayPort
- 3 x USB 3.0
- 1 x USB 3.1 Type-C
- RJ-45
Price 1499e
-Tommi
#4 Posted : Sunday, January 8, 2017 4:47:50 PM(UTC)
I have a 4 years old Asus ROG G750J with i7 4700HQ, 8G RAM and a GTX770m. Supports easily up to 6 HD sources (from TB, USB and NDI) for streaming and recording.
You should be fine. I'd suggest to replace the 1TB HD by a SSD...
-TA_
#5 Posted : Wednesday, January 11, 2017 1:38:52 AM(UTC)
-TA_
OK, thanks. I made it safe and bought ASUS GL702VM and replaced 2nd HDD to SSD :-)
-tommi
Similar Topics
Laptop CPU and GPU requirements for 2 streams and 1 recording (Systems)
by Erik_Sweden 7/10/2020 9:43:14 PM(UTC)
Mobile workstation (best CPU and GPU choices) for vMIx and capture card latency (Hardware Compatibility)
by Luke 10/18/2016 11:06:36 PM(UTC)
