Feature Requests
Saving mixing data for multicorder/instant replay for post production
Thanks: 38 times Was thanked: 39 time(s) in 35 post(s)
I don't know if it's possible to achieve something like this, but it would be great to have the live switching/mixing data combined with the multicorder/instant replay recordings in a Adobe Premiere compatible format (or something that's compatible with a wide variety of editing programs). So when I go into post production I can load the multicorder/instant replay recordings and have all data from my live switching in a multicam workspace. This way I only have to adjust some camera angles and, add transitions and save a lot of time in post production, because it's easier to edit and adjust the live switching later on than to start from scratch. The workflow would be tremendous this way.
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Ok, I guess I have bad memory or something, but thanks! :-D
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
A workaround for this could be - Davinci Resolve has a scene detection function that will find the edits in your master vMix file. Then export an EDL or edit in Resolve. In Premier use the EDL to assemble the sequence from the master file, adding edits to the continuous file. Use multicam mode and sync the other recordings together. This will work in Avid, there is something similar in Premier. You should now be able to switch between shots and trim. An EDL from vMix would be a lot easier ! Here's an expensive looking EDL recorder derived from the tallies - http://www.edl-rec.com/products.html
Feature Requests
