Rinsky
#1 Posted : Saturday, January 7, 2017 10:18:06 AM(UTC)
Rinsky
I don't know if it's possible to achieve something like this, but it would be great to have the live switching/mixing data combined with the multicorder/instant replay recordings in a Adobe Premiere compatible format (or something that's compatible with a wide variety of editing programs). So when I go into post production I can load the multicorder/instant replay recordings and have all data from my live switching in a multicam workspace. This way I only have to adjust some camera angles and, add transitions and save a lot of time in post production, because it's easier to edit and adjust the live switching later on than to start from scratch. The workflow would be tremendous this way.
richardgatarski
#2 Posted : Saturday, January 7, 2017 10:47:16 AM(UTC)
richardgatarski
This is a nice request, at least judging from two other ones that I believe are the same reguest ;)
Edit: And Rinsky, you actually have already +1'ed the latter
Event logging function that creates a CMX EDL file
MultiCorder for edit multicam Adobe Premiere, Mediacomposer or Finalcut
Rinsky
#3 Posted : Saturday, January 7, 2017 5:00:33 PM(UTC)
Rinsky
Ok, I guess I have bad memory or something, but thanks! :-D
Peter B
#4 Posted : Saturday, January 7, 2017 8:47:11 PM(UTC)
Peter B
A workaround for this could be -
Davinci Resolve has a scene detection function that will find the edits
in your master vMix file. Then export an EDL or edit in Resolve.
In Premier use the EDL to assemble the sequence from the master file, adding
edits to the continuous file.
Use multicam mode and sync the other recordings together. This will work in
Avid, there is something similar in Premier.
You should now be able to switch between shots and trim.
An EDL from vMix would be a lot easier !
Here's an expensive looking EDL recorder derived from the tallies -
http://www.edl-rec.com/products.html
