BluestemVideo
#1 Posted : Friday, January 6, 2017 7:11:16 PM(UTC)
BluestemVideo
Has anyone here built a Mini itx system?
Obviously a huge limitation is having only one pci slot. That would require you to make a decision about a GPU or Capture device.
I cannot find the page anymore for the vMix U system but would assume it was built on a mini itx board since it is 1U.
Was it just running off the CPU for processing?
Thanks for any help!
BETech
#2 Posted : Friday, January 6, 2017 9:15:26 PM(UTC)
BETech
A system build worth a look, having built two systems for clients. 19" 1U Short Depth (9.8") Rackmount PC - Intel® 6th Gen Core i7/i5/i3, H170 Chipset; Up to 32GB RAM, SSD or HDD, 1 x PCIe 3.0 x 16 (optional, via riser), 2 x LAN, DVI-D + HDMI Video, 4 x USB2, 8 USB3. Optional Wifi & Bluetooth. https://www.superlogics....-AH170I-GC/265-5835.htm#
Motherboard ASRock Z170M-ITX/ac http://www.asrock.com/mb/Intel/Z170M-ITXac/
Intel HD Graphics 510/530. Don’t forget to purchase high performance/speed DDR4 memory, as the graphics use shared memory. Recommend 16GB (2x8GB).
vMix with Blackmagic Decklink Duo2 HD-SDI interface.
Client/s specification & usage: 3 x 1080i50 Sony HDC1500 cameras, 1 x 1080i50 HD-SDI output for MATV system, 1 x 1080i50 master recording and 1 x HD output for streaming. Other inputs include: 2 x DDR Video lists, 2 x Graphics (photos etc), 1 x PowerPoint, and multiple inputs for vMix Titles.
Dual boot Windows 8.1 Professional (redundancy), all Windows Store Apps removed, Classic Shell StartMenu, Classic Windows interface built on Samsung SSD EVO 500GB, with 2TB 2.5” HDD for multimedia.
Hope this helps. Cheers.
The vMix “U” product page : http://www.vmix.com/products/vmix-u.aspx
thanks 1 user thanked BETech for this useful post.
BluestemVideo on 1/7/2017(UTC)
BluestemVideo
#3 Posted : Saturday, January 7, 2017 12:19:35 AM(UTC)
BluestemVideo
Thanks!
How many camera feeds did you ingest with this system? Did you also stream at 1080 with it?
vMix with Blackmagic Decklink Duo2 HD-SDI interface. Hope this helps. Cheers.
BluestemVideo
#4 Posted : Saturday, January 28, 2017 4:52:04 PM(UTC)
BluestemVideo
I have built the Mini ITX machine! Below are the specs:
I have a much larger computer in my studio but had the need to build this one to travel with for small shows.
With 3 HD-SDI feeds coming in and 3 HD videos looping while recording 1080 and streaming 1080 it runs at about 60% CPU.
Next upgrade will but an Nvidia GPU in the case and use an external device for capture.
vMix Computer Build:
Operating System: Windows 10 Pro
Software: vMix
Motherboard: https://www.amazon.com/g...01_s01?ie=UTF8&psc=1
CPU: https://www.amazon.com/g...00_s01?ie=UTF8&psc=1
Memory: https://www.amazon.com/g...o00_s00?ie=UTF8&th=1
SSD: https://www.amazon.com/g...01_s02?ie=UTF8&psc=1
Power Supply: https://www.amazon.com/g...01_s02?ie=UTF8&psc=1
Case: https://www.amazon.com/g...02_s00?ie=UTF8&psc=1
Case Fan: https://www.amazon.com/g...01_s00?ie=UTF8&psc=1
Capture Card: https://www.bhphotovideo...KDVQD_DeckLink_Quad.html
System Photo
Siroki
#5 Posted : Sunday, January 29, 2017 7:23:51 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
I like your case. I would only put maybe i7 CPU. But its nice little case. Great
Kelvin
#6 Posted : Sunday, January 29, 2017 11:06:38 PM(UTC)
Kelvin
Why did you choose the BM Decklink Quad over the Duo 2? They have the same number of inputs/outputs, but the Duo2 is half the price?
BluestemVideo
#7 Posted : Monday, January 30, 2017 1:40:44 PM(UTC)
BluestemVideo
Siroki - Thanks the case is decent. I will upgrade to an i7 when they release more Kaby Lake with Iris Pro.
Kelvin - I had it on the shelf already out of another machine. Otherwise I would have gone with the Duo2 and will in the future.
RichShumaker
#8 Posted : Monday, March 6, 2017 5:56:27 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
M.2 SSD was the game changer for me as the speed it works at it ridiculously fast.
4 times faster than traditional SSD.
Also I use my M.2 not as a OS drive but as my Capture, Record, and Playback drive.
Rich Shumaker
