I also have similar problems. I have a powerful laptop MSI. when playing some fail CPU is very high , with the same files on the other computer are working fine. Here are some screenshots, have you got any thoughts about that? Michail attached the following image(s):  2017-01-05_16-28-32.png (1,013kb) downloaded 1 time(s). 2017-01-05_16-38-59.png (34kb) downloaded 2 time(s). 2017-01-05_16-47-44.png (169kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Here is a screenshot of CPU Michail attached the following image(s):  2017-01-05_16-28-32.png (1,013kb) downloaded 8 time(s).You cannot view/download attachments. Try to login or register.
Update the Nvidia driver.
Did you check what process is using your CPU with taskmanager?
You have been a member since:: 1/13/2010(UTC) Posts: 5,304  Location: Gold Coast, Australia Was thanked: 4674 time(s) in 1609 post(s)
I've moved this to a separate thread as it is a different issue. (high laptop render times are usually due to old drivers, or vMix not set to run using dedicated graphics)
ovinas wrote:Update the Nvidia driver.
Did you check what process is using your CPU with taskmanager? yes driver new. what do you mean? what process? explain in more detail Michail attached the following image(s):  2017-01-05_22-44-21.png (147kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
admin wrote:I've moved this to a separate thread as it is a different issue. (high laptop render times are usually due to old drivers, or vMix not set to run using dedicated graphics) I launched vmix with a card of Nvidia and with intel card. About Intel everything is absolutely bad... with a card of Nvidia too, big CPU. I tried to reinstall vmix and tried to be rolled away to the 17th version... there is nothing doesn't help. I have a base unit of the characteristic of which a little better. In case of reproduction of files from it it isn't higher than 12% of CPU. Michail attached the following image(s):  2017-01-05_21-39-38 (2).png (96kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
