Michail
#1 Posted : Friday, January 6, 2017 9:46:02 AM(UTC)
Michail
I also have similar problems. I have a powerful laptop MSI. when playing some fail CPU is very high , with the same files on the other computer are working fine. Here are some screenshots, have you got any thoughts about that?
Michail attached the following image(s):
Michail
#2 Posted : Friday, January 6, 2017 9:51:25 AM(UTC)
Michail
Here is a screenshot of CPU
ovinas
#3 Posted : Friday, January 6, 2017 10:23:58 AM(UTC)
ovinas
Update the Nvidia driver.
Did you check what process is using your CPU with taskmanager?
#4 Posted : Friday, January 6, 2017 10:37:59 AM(UTC)
Was thanked: 4798 time(s) in 1647 post(s)
I've moved this to a separate thread as it is a different issue. (high laptop render times are usually due to old drivers, or vMix not set to run using dedicated graphics)
Michail
#5 Posted : Friday, January 6, 2017 4:40:06 PM(UTC)
Michail
yes driver new.
what do you mean? what process? explain in more detail
Michail
#6 Posted : Friday, January 6, 2017 4:44:12 PM(UTC)
Michail
I launched vmix with a card of Nvidia and with intel card. About Intel everything is absolutely bad... with a card of Nvidia too, big CPU.
I tried to reinstall vmix and tried to be rolled away to the 17th version... there is nothing doesn't help.
I have a base unit of the characteristic of which a little better. In case of reproduction of files from it it isn't higher than 12% of CPU.
2017-01-05_21-39-38 (2).png (96kb) downloaded 0 time(s).
