4 Pages<1234>
#21 Posted : Friday, December 9, 2016 10:22:37 AM(UTC)
Oscar,
Can you please drop an email to info@vmix.com.au as it is quite odd that none of these cards show up in the list
as we use the new Magewell SDK in 18 which should detect all of them.
Thanks,
richardgatarski
#22 Posted : Saturday, December 10, 2016 12:10:20 PM(UTC)
richardgatarski
Seems still in v18.0.0.57 the little bug in Scripts that Function=PreviewInput only works when input is specified by number, not by name. (as reported in the v18 preview topic)
#23 Posted : Sunday, December 11, 2016 12:37:08 AM(UTC)
Bunch of updates and fixes just added to 18.0.0.58. See below for more info:
http://forums.vmix.com/d...ts&m=31945#post31945
ON.tv Channels on 12/11/2016(UTC)
ON.tv Channels
#24 Posted : Sunday, December 11, 2016 8:21:39 AM(UTC)
ON.tv Channels
Thanks Guys for a very prompt response to my request for: Added generic graphic for X-keys and MIDI to Shortcuts Templates window...
Fantastic!
green-screen-uk
#25 Posted : Saturday, December 17, 2016 6:37:27 AM(UTC)
green-screen-uk
Updated to vmix 18 and no longer have my Black magic decklink card working in vmix. I know the card and drivers are not at fault as they still work in wirecast and black magic media express.
I have tried all legacy options and still have no video coming in from the card in vmix 18. Everything was fine in vmix 17, can I downgrade my update?
Cpilcher
#26 Posted : Saturday, December 17, 2016 11:49:52 AM(UTC)
Cpilcher
If you want to downgrade you can reinstall the last version of VMix 17, or any other version you may want, right over the top of the previous install. I don't have any help for you with the decklink cards though.
Chuck
mistergee
#27 Posted : Tuesday, December 20, 2016 7:47:55 AM(UTC)
mistergee
Same thing here with Intensity Shuttle USB3. Have had to reinstall earlier version of vMix. I chose to drop back to v 16
zenvideo
#28 Posted : Tuesday, December 20, 2016 11:17:34 AM(UTC)
zenvideo
Interesting... I can get my Intensity Shuttle to work as an input in vMix 18, although I did have a problem at first because it had previously been used as an output device and was still selected as an option for the External Renderer. I got a brief flash of the input and then black, even though the main External stop/start button along the bottom wasn't active. Once I completely removed it from the External Output settings (and restarted vMix), it worked fine as an input.
#29 Posted : Tuesday, December 20, 2016 3:25:23 PM(UTC)
There have been no changes to Decklink functionality in vMix 18 other than to hide the legacy devices that tended to cause problems for most users.
Only thing I can think of is the video format selected for the camera may have changed when upgrading versions, so double check the frame rate exactly
matches what the camera is sending, paying particular attention to if it is interlaced or not.
Failing that please drop us an email at info@vmix.com.au
Thanks,
madness
#30 Posted : Sunday, January 1, 2017 1:14:25 PM(UTC)
madness
Is image sequencing broken in the latest version of vMix? I selected the first image of the sequence for the input, and it only sees that one image, I cannot import more than the one image as expected by reading the help info, but it only imports that one image, and has no animation.
#31 Posted : Sunday, January 1, 2017 10:12:45 PM(UTC)
Works fine here, how are the files numbered?
madness
#32 Posted : Monday, January 2, 2017 10:24:24 PM(UTC)
madness
Sequentially starting at 0001.
#33 Posted : Monday, January 2, 2017 11:08:26 PM(UTC)
Could you zip them up and email them to us? Must be something not quite right with the numbering.
#34 Posted : Tuesday, January 3, 2017 12:18:24 AM(UTC)
Thanks for sending it through. The image sequence filenames will need a name at the start of the numbers
in order to be detected correctly. For example image0001.png instead of just 0001.png
madness
#35 Posted : Tuesday, January 3, 2017 2:58:39 PM(UTC)
madness
Thanks Martin! That was it! I swear I had that working in previous releases as it was.
mburel1980
#36 Posted : Wednesday, January 4, 2017 5:32:13 AM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
Possible Bug?
When we were streaming live on the weekend we unticked Overlay 1 for Recording/External on Output Settings to record a clean feed.
But as we verified the final output stream, the overlay wasn't in the stream either. Only after ticking it on again, the logos showed up again in the stream.
Marc
#37 Posted : Wednesday, January 4, 2017 3:00:53 PM(UTC)
@ mburel1980
AFAIK, internal 'Recording' and 'Streaming' use the same feed in vMix (Recording/External => Output/Preview/MultiView/ or Input).
If you want to Stream 'Program Out' but record a "clean" feed sans Overlay, you may need to record externally from either the "Fullscreen" or "External 2" feeds if you have that capability.
The "MultiCorder" feature will also record individual Camera Inputs independently of "Program Out" but that is probably not what you want.
richardgatarski
#38 Posted : Thursday, January 5, 2017 1:54:14 PM(UTC)
richardgatarski
v 18.58:
Fixed PreviewInput/ActiveInput shortcuts not working with Input names in API
Still does not work in Scripts (tested with 18.58).
v 18.59
Added higher bitrate AAC audio options for MP4 recording using a new improved encoder
I am not sure what "transient artefacts" are, but this fall I noticed a kind of metallic sounding artefacts from the mikes in our studio. Just tried increasing the audio bitrate to 384 mbps, and the artefact disappeared (or my ears can't hear them). So thanks! (But I don't think we had this issue earlier, say spring 2016, with the same hw in the studio).
pm
#39 Posted : Wednesday, January 11, 2017 7:51:28 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
I did my first sports productions with version 18.0.0.59.
Changes:
Instant Replay - new features added to Instant Replay include 8 Event tabs, up from four, 3 digit ID codes assigned to each event and the order events irrespective of timecode.
Also one change from 17 to 18 regarding Instant Replay was, that the progress bar shows the total duration of the selected events and camera angles. I like this change a lot and it makes operation easier.
But now, like it is implemented, I have the opposite problem: I don't see anymore (like in 17) the duration/progress bar of each camera angle. I decided with this information if vMix should go to the next event for itself or I should force vMix to go to the next angle manually (because the out mark is to far away). Now, if I press "next angle" at the wrong moment (almost the same time as vMix would switch), vMix jumps over one angle.
Possible solution:
Above the overall progress bar, a small progress bar in another color (height only a few pixels), which shows the duration of the current angle. There is no time information required, only the progress bar. With this solution, we can address both needs.
Patrick
motest
#40 Posted : Wednesday, January 11, 2017 8:24:07 AM(UTC)
motest
i've to report a couple of small bugs in the last version:
setup: FMLE streaming with multiple bitrate
- in the streaming "view status" panel is impossible to scroll down to get the FMLE Publishing status (buffer, frame drop)
- in the streaming setup panel the audio goes automatically on 96kbps, even if i change it to a lower or higher bitrate; the problem is solved only when i input the text manually and hit return.
The rest is all AWESOME
Thanks and happy new year to everyone!
Guest (11)
4 Pages<1234>
