JimJacobs
#1 Posted : Tuesday, December 27, 2016 8:45:25 PM(UTC)
JimJacobs
I am trying to use Data Sources in vMix to accomplish something I need for an upcoming Motorsports event I'm doing in January.
I want to be able to take the ENTRY # off the sheet and place it into a location and all the other columns from that ROW populate at the same time. Now this is obviously easily accomplished as a lower third, but I'm trying to use this to develop a Starting Line-Up Graphic and Running Order graphic.
This requires that all data associated with a specific ROW needs to be able to be PLACED quickly.
I've attached two screen shots. 1st is of the actual Excel Spreadsheet layout with some sample data in it.
Screenshot #2 is of the Line-Up template designed in LIVE TEXT. I want to put the Car # & Driver Name (2) per box, then by just entering their ENTRY # off the spreadsheet, the car # and driver name automatically changes with the associated ROW.
I can't figure it out...not sure it can be done. Any suggestions??
JimJacobs attached the following image(s):
Screenshot 1.jpg (247kb) downloaded 27 time(s).
Screenshot 2.jpg (252kb) downloaded 27 time(s).
#2 Posted : Wednesday, December 28, 2016 5:23:24 AM(UTC)
Is the list in order of startgrid position ?
have you tried the convert rows to columns option ?
