Excel Spreadsheets In Data Source
Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
I am trying to use Data Sources in vMix to accomplish something I need for an upcoming Motorsports event I'm doing in January. I want to be able to take the ENTRY # off the sheet and place it into a location and all the other columns from that ROW populate at the same time. Now this is obviously easily accomplished as a lower third, but I'm trying to use this to develop a Starting Line-Up Graphic and Running Order graphic. This requires that all data associated with a specific ROW needs to be able to be PLACED quickly. I've attached two screen shots. 1st is of the actual Excel Spreadsheet layout with some sample data in it. Screenshot #2 is of the Line-Up template designed in LIVE TEXT. I want to put the Car # & Driver Name (2) per box, then by just entering their ENTRY # off the spreadsheet, the car # and driver name automatically changes with the associated ROW. I can't figure it out...not sure it can be done. Any suggestions?? JimJacobs attached the following image(s):  Screenshot 1.jpg (247kb) downloaded 27 time(s). Screenshot 2.jpg (252kb) downloaded 27 time(s).You cannot view/download attachments. Try to login or register.
Is the list in order of startgrid position ? have you tried the convert rows to columns option ?
