Instant Replay
Master sound OFF when palying replay
Thanks: 1 times Was thanked: 5 time(s) in 2 post(s)
Hi!
I found out that if I take sound in from HDMI capture input (Avermedia c127 or Magewell USB3 HDMI) all is good until when I play replay. When replay is played sound is cutted off in cam input and when replay is done sound comes back. So there is no sound in stream while replaying.
Replay sound is set to Master. And all is working if i take sound from mixer through mic input.
Reg.Tommi
This probably happens because of "Automatically Mix Audio", which is a feature that mixes audio depending on transition of what is in program. In your case, the audio from your camera is present when the camera input is in program. When a replay is played back, the audio mixer switches off the audio from the camera, and puts on the audio from the replay clip. To keep the audio from the camera on, tick off the button (so it is disabled) for "Automatically Mix Audio"  for the camera input. See more at the vMix help page for Audio mixer: http://www.vmix.com/help18/Mixer.htmlHopes this makes sense. Cheers Jens Stigaard
@ -TA_
Sounds like your audio is set to "Audio follows Video" instead of "Always ON", if I understand you correctly. If so, you'll need to de-select the double arrow icon on the Input that carries your audio and turn on the audio. (the danger here is that the audio is always on, so you may need to make adjustments when playing other elements like videos)
Yep that was it. Thanks both
-tommi
Instant Replay
