NDI
No NDI Sources, it only works some times.
Im having a problem with NDI where almost all of the time i get no NDI sources available, the wheel thing just keeps spinning and finds no sources. The problem is the same with NDI VIdeo Monitor it only works some of the time. I have to restart vmix multiple times till it finally finds a NDI source and this happens all the time and its causing big problems for me. The 3 pcs I have vmix installed on is the same problem. network is set to private on all 3 of the machines. Is there something I am missing? I am using Vmix 17.0.0.111. Any insight would be helpful. Thanks
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
Some PC's are not NDI compatible. Share your PC specs.
- Tom
Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Gigabit network with cat6 cables?
g-mo wrote:Gigabit network with cat6 cables? I think Tom means things like the CPU - not all CPUs can exectute the instructions in the NDI DLLs. There's more info on the NewTek website as to the PC requirements for running NDI. However, the fact that it even works some of the time suggests that this is not the cause of the problem, or else it would probably never work, but I'm afraid I don't know what would cause an issue like this.
I understand what Tom is saying but I've heard of similar problems using a slower network.
gigabit network with CAT5E Cables
Joined: 1/13/2010(UTC) Posts: 5,313  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
Try installing the latest vMix 18 update (18.0.0.58) and see if that helps with locating sources as there have been a few fixes since 17.111
Martin vMix
NDI
