boris9831
#1 Posted : Friday, December 16, 2016 7:27:40 PM(UTC)
boris9831
I have several Amcrest (HD 1080) PTZ IP cameras (price point $100) that are ONVIF compatible. PTC Optics has a product that will control these - PTZOptics IP Joystick Controller with ONVIF Protocol for All PTZ Security Cameras. I have installed PTZoptics cameras (20X) and was able to get the the PTZ on a vMix Input to work with both the IP and direct Camera connection config on the camera. It would be great to be able do that with the Amcrest or any other ONVIF camera. I have tested it on the 3 cameras you have listed but it doesn't work.
thanks 1 user thanked boris9831 for this useful post.
nottooloud on 7/8/2020(UTC)
ask
#2 Posted : Friday, December 16, 2016 8:33:03 PM(UTC)
ask
From the help files:
Selecting the PTZ camera Device Type
Select the device type that matches your camera from the Device Type dropdown box.
vMix currently supports the following types of PTZ cameras:
PTZ Optics cameras and and other cameras that support the VISCA over UDP protocol such as ValueHD.
Panasonic PTZ cameras that support CGI control over Ethernet including the AW-HE40, 50, 60, 65, 70, 120 and 130 series
Sony PTZ cameras that support CGI control other Ethernet including the SRG-300 series.
It is important to note that for simplicity and ease of use, only PTZ cameras that support network control are supported.
Cameras that only have serial control such as via the VISCA or Pelco RS-422 or RS-232 protocols are not currently supported.
boris9831
#3 Posted : Monday, December 19, 2016 6:26:45 AM(UTC)
boris9831
Thank you for the reply. I was hoping ONVIF could be added as a possible addition to the PTZ list of available cameras.
boris9831
#4 Posted : Monday, June 19, 2017 4:45:02 PM(UTC)
boris9831
I now support a church that is using Vmix with 4 Flir IP PTZ security cams and Onvif control would really be helpful in controlling the PTZ function inside of Vmix.
richardgatarski
#5 Posted : Thursday, June 22, 2017 3:36:40 AM(UTC)
richardgatarski
+1
I recently learned that the Axis v5914 and v5915 (and perhaps other cameras from this brand) can be enabled for ONVIF. As I, and many other users, have requested PTZ control in vMix for these cameras, ONVIF support could be the solution
boris9831 on 6/23/2017(UTC)
kricher1964
#6 Posted : Friday, June 23, 2017 1:59:42 PM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
+1 on this
thanks 1 user thanked kricher1964 for this useful post.
Amokka
#7 Posted : Friday, June 23, 2017 5:02:44 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
+1
Streamevent
#8 Posted : Saturday, June 24, 2017 6:18:49 AM(UTC)
Streamevent
+1
podworx
#9 Posted : Tuesday, August 22, 2017 2:06:02 AM(UTC)
podworx
#10 Posted : Tuesday, August 22, 2017 2:21:05 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Unfortunately there are no plans to add ONVIF support, as our tests on a number of these cameras have concluded that most manufacturers
only provide a very limited subset of PTZ control support via ONVIF which is not enough to work with vMix.
Barney Box Lane on 11/6/2019(UTC)
kricher1964
#11 Posted : Saturday, August 26, 2017 10:38:38 PM(UTC)
kricher1964
That's too bad. I was hoping even for simple pan and tilt function, or anything. The protocol seems popular enough that I'm surprised there isn't something that could be done. Thank you for considering though.
serge
#12 Posted : Wednesday, July 10, 2019 1:02:00 AM(UTC)
serge
Canada
+1
We use Axis PTZ HD Cameras and hoping vMix will add PTZ support internally.
streamworks
#13 Posted : Friday, November 1, 2019 7:35:33 PM(UTC)
streamworks
Onvif support would be much appreciated. We own several older Bosch IP camera's with ONVIF protocol. C'mon VMIX, let's do this!
nottooloud
#14 Posted : Wednesday, July 8, 2020 1:48:52 AM(UTC)
nottooloud
+1. Even the simplest pan and tilt would be great.
Guest (7)
