                Can we be able to add a slide or image and especially remove a slide from the list in the slide picker would be awesome seeing as Im sure somebody's client has wanted to add or remove a slide 3 minutes into a conference ? Or if not delete then hide option? A right click option to add hide remove? Thanks Also if at any point would be amazing to have abitlity to choose a different output like a matrix or 2 buss switcher also yes if possible someone asked if can be able to use a custom preview size to gain real estate per bank.....Thank you very much program is very very good
              2 users thanked bandaide for this useful post.
 Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
  Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
                I use Powerpoint to create slides for a daily weather broadcast and Vmix to record and broadcast the show. It would be helpful if I could change a slide or rearrange the sequence without having to make the changes within Powerpoint and then reload Vmix in order to recognize the changes. If anyone has another way of doing this, please advise. I think I could use Powerpoint on a separate PC do so via NDI, but it would be helpful to do this with one PC.
              1 user thanked samrikard for this useful post.
  Thanks: 45 times Was thanked: 3 time(s) in 3 post(s)
  Thanks: 24 times Was thanked: 6 time(s) in 5 post(s)
                +1 (although using the free NDI on a laptop I have used PowerPoint as an input)
                samrikard wrote:I use Powerpoint to create slides for a daily weather broadcast and Vmix to record and broadcast the show. It would be helpful if I could change a slide or rearrange the sequence without having to make the changes within Powerpoint and then reload Vmix in order to recognize the changes. If anyone has another way of doing this, please advise. I think I could use Powerpoint on a separate PC do so via NDI, but it would be helpful to do this with one PC.   Once you load the powerpoint presentation into vMix, open the settings. You can now drop and drag the slides and change the order. http://www.vmix.com/help...m?SlideShowSettings.html
