bandaide
#1 Posted : Tuesday, November 22, 2016 1:56:17 AM(UTC)
bandaide
Can we be able to add a slide or image and especially remove a slide from the list in the slide picker would be awesome seeing as Im sure somebody's client has wanted to add or remove a slide 3 minutes into a conference ? Or if not delete then hide option? A right click option to add hide remove?
Thanks Also if at any point would be amazing to have abitlity to choose a different output like a matrix or 2 buss switcher also yes if possible someone asked if can be able to use a custom preview size to gain real estate per bank.....Thank you very much program is very very good
thanks 2 users thanked bandaide for this useful post.
samrikard on 12/7/2016(UTC), al4video on 12/16/2016(UTC)
samrikard
#2 Posted : Wednesday, December 7, 2016 12:44:07 PM(UTC)
samrikard
I use Powerpoint to create slides for a daily weather broadcast and Vmix to record and broadcast the show. It would be helpful if I could change a slide or rearrange the sequence without having to make the changes within Powerpoint and then reload Vmix in order to recognize the changes. If anyone has another way of doing this, please advise. I think I could use Powerpoint on a separate PC do so via NDI, but it would be helpful to do this with one PC.
thanks 1 user thanked samrikard for this useful post.
al4video
#3 Posted : Friday, December 16, 2016 2:54:06 PM(UTC)
al4video
+1
boris9831
#4 Posted : Friday, December 16, 2016 7:30:25 PM(UTC)
boris9831
+1 (although using the free NDI on a laptop I have used PowerPoint as an input)
ask
#5 Posted : Friday, December 16, 2016 8:31:07 PM(UTC)
ask
Once you load the powerpoint presentation into vMix, open the settings. You can now drop and drag the slides and change the order.
http://www.vmix.com/help...m?SlideShowSettings.html
