Good day everyone, i just wanna ask if it's possible to put image/logo on the ticker. How can i do it?
Thank you in advance!
Assuming you want dynamic inline images, my best guess is to use Data Sources, which I believe will bring in graphics and text. You will probably have to define everything in an xml file and use that as the data source. That way you should be able to dynamically alter the images. If you want to add a static image, you can modify the existing ticker template to display the image required. To do this copy the titles directory from the installed location to another location on your PC. Open vMix Title Designer. Open the title you want to modify and add your image. Resize and repostion. Save as "another" title name. Now when you open this up in vMix it will show your image on top of the ticker bar (or wherever you positioned it). You can also hand edit the XAML file if you are confident. ask attached the following image(s):  vMix Capture 11 December 2016 13-49-15.png (10kb) downloaded 131 time(s).You cannot view/download attachments. Try to login or register.
 2 users thanked ask for this useful post.
@ask thank you, I will try that...
Joined: 12/16/2016(UTC) Posts: 1 Location: 257 Fireweed Ln, Ketchikan, AK, 99901
Thanks @ask I was also looking for this.
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: ask  Assuming you want dynamic inline images, my best guess is to use Data Sources, which I believe will bring in graphics and text. You will probably have to define everything in an xml file and use that as the data source. That way you should be able to dynamically alter the images.
If you want to add a static image, you can modify the existing ticker template to display the image required. To do this copy the titles directory from the installed location to another location on your PC. Open vMix Title Designer. Open the title you want to modify and add your image. Resize and repostion. Save as "another" title name. Now when you open this up in vMix it will show your image on top of the ticker bar (or wherever you positioned it). You can also hand edit the XAML file if you are confident. Hi ASK i'm looking to bind an image to the end of any text segment in vmix titles i also started vmix web API & can set text or image or visibility but not such thing i found [mytext] [mylogo] [mytext] i also read your previous post there https://forums.vmix.com/...ts/t8467-Image-on-tickerit was useful and hope you can help me doing this one tnx alot
