roughpear
#1 Posted : Sunday, December 11, 2016 9:47:03 PM(UTC)
roughpear
Good day everyone, i just wanna ask if it's possible to put image/logo on the ticker. How can i do it?
Thank you in advance!
ask
#2 Posted : Sunday, December 11, 2016 10:48:44 PM(UTC)
ask
Assuming you want dynamic inline images, my best guess is to use Data Sources, which I believe will bring in graphics and text. You will probably have to define everything in an xml file and use that as the data source. That way you should be able to dynamically alter the images.
If you want to add a static image, you can modify the existing ticker template to display the image required. To do this copy the titles directory from the installed location to another location on your PC. Open vMix Title Designer. Open the title you want to modify and add your image. Resize and repostion. Save as "another" title name. Now when you open this up in vMix it will show your image on top of the ticker bar (or wherever you positioned it). You can also hand edit the XAML file if you are confident.
ask attached the following image(s):
vMix Capture 11 December 2016 13-49-15.png (10kb) downloaded 133 time(s).
thanks 2 users thanked ask for this useful post.
roughpear on 12/13/2016(UTC), Sarajordan on 12/16/2016(UTC)
roughpear
#3 Posted : Tuesday, December 13, 2016 12:34:02 AM(UTC)
roughpear
@ask
thank you, I will try that...
Sarajordan
#4 Posted : Friday, December 16, 2016 6:45:11 AM(UTC)
Sarajordan
Thanks @ask I was also looking for this.
User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#5 Posted : Wednesday, August 10, 2022 2:02:07 PM(UTC)
Winops
Argentina
Hi ASK
i'm looking to bind an image to the end of any text segment in vmix titles
i also started vmix web API & can set text or image or visibility
but not such thing i found
[mytext] [mylogo] [mytext]
i also read your previous post there
https://forums.vmix.com/...ts/t8467-Image-on-ticker
it was useful
and hope you can help me doing this one
tnx alot
