artciukas
#1 Posted : Wednesday, December 14, 2016 5:22:37 AM(UTC)
artciukas
I want to buy PTZ camera JVC KY-PZ100. But question is: can i control with vMix 17.
vMix 17 support protocol to control this camera?
Link:
http://pro.jvc.com/prof/...s.jsp?model_id=MDL102404
Thanks.
Arturas
SportsNetUSA.net
#2 Posted : Wednesday, December 14, 2016 2:17:46 PM(UTC)
SportsNetUSA.net
Check out this post on the forum from Kane Patterson of NewTek
http://forums.vmix.com/default.aspx?g=posts&t=8477
Panasonic just announced 'AutoLink' the software product that makes it easy to connect Panasonic IP cameras to a network and convert the IP output into NDI.
http://business.panasoni...sonic-simplify-ip-setup
NewTek AutoLink for Panasonic PTZ https://store.newtek.com...-for-panasonic-ptz.html
Kane Peterson
NewTek
The Panasonic AW-HE40 seems to be in the same price range as the JVC KY-PZ100, and would support NDI. The other two Panasonic models, AW-UE70 and AWHE130 would be priced much higher than the JVC KY-PZ100.
kane
#3 Posted : Wednesday, December 14, 2016 5:56:28 PM(UTC)
kane
Just be aware that AutoLink will automatically get the video and audio from the Panasonic PTZ into an NDI solution (like vMix or TriCaster).
For PTZ control, that is still up to the source system to do. I'm not sure what vMix supports PTZ wise (TriCaster does support Panasonic PTZ control).
Kane Peterson
NewTek
vmixsupport
#4 Posted : Wednesday, December 14, 2016 7:54:58 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Here is a list of current supported PTZ models for control in vMix-
-Panasonic PTZ cameras that support CGI control over Ethernet including the AW-HE40, 50, 60, 65, 70, 120 and 130 series
-Sony PTZ cameras that support CGI control other Ethernet including the SRG-300 series.
-PTZ Optics cameras and and other cameras that support the VISCA over UDP protocol such as ValueHD.
artciukas
#5 Posted : Saturday, March 11, 2017 5:39:11 AM(UTC)
artciukas
JVC KY-PZ100 upgrade firmware to standart ptz camera protocol and add web port access.
What's new:
Standard control protocol over LAN (enables PTZ control by TriCaster and other products)
PELCO-D control protocol via RS-422/485
Added 640x360 @50/60p streaming format
Automatic streaming resume after network disconnect
Streaming to JVC VIDEOCLOUD presets
Selectable web access port #
Selectable Pan/Tilt moving range: Type 1-7
Can i control JVC KY-PZ100 camera with vMix 17.0.0.111?
Connect to tricaster manual:
http://pro.jvc.com/pro/a.../KY-PZ100_TricMini-A.pdf
Thanks for answer
Arturas
sinc747
#6 Posted : Saturday, March 11, 2017 4:16:46 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Why not download the 60-day free trial and test it? Get it here.
- Tom
artciukas
#7 Posted : Sunday, March 12, 2017 6:05:23 AM(UTC)
artciukas
I tried but for me not working.
corporatejames
#8 Posted : Saturday, July 29, 2017 2:53:25 AM(UTC)
corporatejames
Can confirm that you are correct @articiukas
I have had one sent to me for testing and will either have this one or another on from JVC sent to Vmix for testing and see if can be added quickly to supported cams
