Thanks: 1 times Was thanked: 6 time(s) in 5 post(s)
Check out this post on the forum from Kane Patterson of NewTek http://forums.vmix.com/default.aspx?g=posts&t=8477Quote:Panasonic just announced 'AutoLink' the software product that makes it easy to connect Panasonic IP cameras to a network and convert the IP output into NDI. http://business.panasoni...sonic-simplify-ip-setup NewTek AutoLink for Panasonic PTZ https://store.newtek.com...-for-panasonic-ptz.html Kane Peterson NewTek The Panasonic AW-HE40 seems to be in the same price range as the JVC KY-PZ100, and would support NDI. The other two Panasonic models, AW-UE70 and AWHE130 would be priced much higher than the JVC KY-PZ100.
Just be aware that AutoLink will automatically get the video and audio from the Panasonic PTZ into an NDI solution (like vMix or TriCaster).
For PTZ control, that is still up to the source system to do. I'm not sure what vMix supports PTZ wise (TriCaster does support Panasonic PTZ control).
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 243 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 159 time(s) in 72 post(s)
Here is a list of current supported PTZ models for control in vMix-
-Panasonic PTZ cameras that support CGI control over Ethernet including the AW-HE40, 50, 60, 65, 70, 120 and 130 series -Sony PTZ cameras that support CGI control other Ethernet including the SRG-300 series. -PTZ Optics cameras and and other cameras that support the VISCA over UDP protocol such as ValueHD.
Hello, JVC KY-PZ100 upgrade firmware to standart ptz camera protocol and add web port access. What's new: Standard control protocol over LAN (enables PTZ control by TriCaster and other products)PELCO-D control protocol via RS-422/485 Added 640x360 @50/60p streaming format Automatic streaming resume after network disconnect Streaming to JVC VIDEOCLOUD presets Selectable web access port #Selectable Pan/Tilt moving range: Type 1-7 Can i control JVC KY-PZ100 camera with vMix 17.0.0.111?Connect to tricaster manual: http://pro.jvc.com/pro/a.../KY-PZ100_TricMini-A.pdfThanks for answer Arturas
Joined: 8/2/2013(UTC) Posts: 1,099   Location: Fairhope, Alabama USA Thanks: 590 times Was thanked: 202 time(s) in 168 post(s)
artciukas wrote:Can i control JVC KY-PZ100 camera with vMix 17.0.0.111?
Why not download the 60-day free trial and test it? Get it here.
- Tom
I tried but for me not working.
Can confirm that you are correct @articiukas I have had one sent to me for testing and will either have this one or another on from JVC sent to Vmix for testing and see if can be added quickly to supported cams
