Feature Requests
IP based Playout and Capture solution
Since there lot of broadcasters and webcasters from all over the world, are part of this forum I would like to ask all of you if there are any software IP based Playout solution other than Cinegy which supports both unicast and multicast feeds as input and output. The solution should also have more or less features given below.
24X7 SD+HD+4k Playout As run logs / Activity logging API integration Redundancy for failures Multi format file support (AVI, MOV, MKV, MPEG1, MPEG2, MP2, MP4, VOB, H.264, MXF, DV, DVCPRO) Insert video clips into playlist in real time without any flicker Drag and drop of files in playlist Last frame freeze or loop playlist Clips can be trimmed Split clips in the playlist Insert command in playlist like stop, pause play Auto ON/OFF of Logo and CG overlay Dual playout support File duration and playlist duration displayed Start time of the clips and end time of the playlist displayed Playlist can be scheduled Supports 4:3 and 16:9 aspect ratio Supports Live input Gapless switching of Live video from playlist Copy and paste of clips in the playlist Group selection of clips for moving up and down Log reports can be generated Unlimited text and Graphics layer Support Flash Animation Flexible template creation Crawl and roll creation Supports animated sequence file Add outline, shadow, glow to text layers CG playlist creation and playback Shortcut for all functions RTMP stream out Virtual device support to Adobe FMLE
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ sagar
Not sure I understand the request??? AFAIK, vMix has a lot of those capabilities (but maybe not all within the vMix software itself), although, it is not considered a "Playout" solution per se. What exactly are you hoping to do, and what have you tried with vMix? You are more likely to get support for individual feature requests for things that you've tried to do with vMix but couldn't (for various reasons) than to itemize a long list of requirements. Just my thoughts.
I have used this: http://www.elementseurope.com/And it seems pretty good! You can download a free trial. But yes, it would be good if the playlist or list feature could have scheduling in vMix
 1 user thanked mashynewie2 for this useful post.
Joined: 10/25/2012(UTC) Posts: 181 Location: Barbados
I can confirm Elite from elementseurope as a good choice. I have been using them from original version called Broadcast Play. Great product.
Maxi
 1 user thanked Maximus for this useful post.
Maximus wrote:I can confirm Elite from elementseurope as a good choice. I have been using them from original version called Broadcast Play. Great product.
Maxi Please share the link for Broadcast Play.
Oh its the same! Do we have any other tested solution?
Feature Requests
