sagar
#1 Posted : Saturday, December 10, 2016 2:48:45 AM(UTC)
sagar
Since there lot of broadcasters and webcasters from all over the world, are part of this forum I would like to ask all of you if there are any software IP based Playout solution other than Cinegy which supports both unicast and multicast feeds as input and output. The solution should also have more or less features given below.
24X7 SD+HD+4k Playout
As run logs / Activity logging
API integration
Redundancy for failures
Multi format file support (AVI, MOV, MKV, MPEG1, MPEG2, MP2, MP4, VOB, H.264, MXF, DV, DVCPRO)
Insert video clips into playlist in real time without any flicker
Drag and drop of files in playlist
Last frame freeze or loop playlist
Clips can be trimmed
Split clips in the playlist
Insert command in playlist like stop, pause play
Auto ON/OFF of Logo and CG overlay
Dual playout support
File duration and playlist duration displayed
Start time of the clips and end time of the playlist displayed
Playlist can be scheduled
Supports 4:3 and 16:9 aspect ratio
Supports Live input
Gapless switching of Live video from playlist
Copy and paste of clips in the playlist
Group selection of clips for moving up and down
Log reports can be generated
Unlimited text and Graphics layer
Support Flash Animation
Flexible template creation
Crawl and roll creation
Supports animated sequence file
Add outline, shadow, glow to text layers
CG playlist creation and playback
Shortcut for all functions
RTMP stream out
Virtual device support to Adobe FMLE
Eapgh
#2 Posted : Saturday, December 10, 2016 4:41:46 AM(UTC)
Eapgh
#3 Posted : Saturday, December 10, 2016 10:36:44 AM(UTC)
@ sagar
Not sure I understand the request???
AFAIK, vMix has a lot of those capabilities (but maybe not all within the vMix software itself), although, it is not considered a "Playout" solution per se.
What exactly are you hoping to do, and what have you tried with vMix?
You are more likely to get support for individual feature requests for things that you've tried to do with vMix but couldn't (for various reasons) than to itemize a long list of requirements.
Just my thoughts.
mashynewie2
#4 Posted : Tuesday, December 13, 2016 5:37:14 AM(UTC)
mashynewie2
Was thanked: 44 time(s) in 33 post(s)
I have used this:
http://www.elementseurope.com/
And it seems pretty good! You can download a free trial.
But yes, it would be good if the playlist or list feature could have scheduling in vMix
thanks 1 user thanked mashynewie2 for this useful post.
sagar on 12/13/2016(UTC)
Maximus
#5 Posted : Tuesday, December 13, 2016 5:53:00 PM(UTC)
Maximus
I can confirm Elite from elementseurope as a good choice. I have been using them from original version called Broadcast Play. Great product.
Maxi
thanks 1 user thanked Maximus for this useful post.
sagar
#6 Posted : Tuesday, December 13, 2016 10:07:13 PM(UTC)
sagar
Maxi
Please share the link for Broadcast Play.
SportsNetUSA.net
#7 Posted : Wednesday, December 14, 2016 1:36:51 PM(UTC)
SportsNetUSA.net
sagar
#8 Posted : Wednesday, December 14, 2016 2:45:01 PM(UTC)
sagar
SportsNetUSA.net wrote:
Oh its the same! Do we have any other tested solution?
