#1 Posted : Tuesday, November 29, 2016 9:25:15 PM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
Cpilcher on 11/29/2016(UTC), vijay6672 on 12/4/2016(UTC)
#2 Posted : Thursday, December 1, 2016 3:09:43 PM(UTC)
18.0.0.56
* Fixed bug in NDI that may cause freezing when loading presets with NDI sources that are offline
* Fixed NDI output crash bug on old AMD systems that do not support it. NDI will now automatically deactivate on those systems to prevent the problem.
thanks 3 users thanked admin for this useful post.
corporatejames on 12/2/2016(UTC), vijay6672 on 12/4/2016(UTC), r5dad on 12/5/2016(UTC)
#3 Posted : Friday, December 2, 2016 2:26:43 PM(UTC)
18.0.0.57
* Fixed an error when playing back Instant Replay events with only Mark In set
corporatejames on 12/2/2016(UTC), vijay6672 on 12/4/2016(UTC), xaver on 12/14/2016(UTC)
#4 Posted : Sunday, December 11, 2016 12:35:50 AM(UTC)
18.0.0.58
* NDI quality fixes and performance improvements
* Added beta JSON data source
* Added Activators support for Novation Launchpad MK2 LED buttons
* Added workaround for bug in latest AMD Radeon drivers
* Added generic graphic for X-keys and MIDI to Shortcuts Templates window
* Fix for Magewell inputs showing up blank when multiple cards are installed
* Fixed PreviewInput/ActiveInput shortcuts not working with Input names in API
thanks 13 users thanked admin for this useful post.
ON.tv Channels on 12/11/2016(UTC), TV97 on 12/11/2016(UTC), BETech on 12/11/2016(UTC), Rinsky on 12/11/2016(UTC), vijay6672 on 12/12/2016(UTC), sinc747 on 12/12/2016(UTC), Stavlin on 12/13/2016(UTC), madness on 12/13/2016(UTC), xaver on 12/14/2016(UTC), SHMD on 12/23/2016(UTC), vadim_d on 12/25/2016(UTC), DWAM on 1/4/2017(UTC), scottyp on 1/24/2017(UTC)
#5 Posted : Thursday, January 5, 2017 7:13:54 AM(UTC)
18.0.0.59
* New "Automatically end stream" checkbox added to Facebook Settings.
This will end the stream immediately after clicking Stop or closing vMix.
* Added higher bitrate AAC audio options for MP4 recording using a new improved encoder
This should improve "transient artefacts" with some microphones
* Multiple X-Keys channels are now sorted manually by vMix instead of relying on Windows sorting which may change when unplugging USB devices.
* Multiple displays are now sorted manually by vMix instead of relying on Windows sorting which may change depending on when the monitors turn on during boot up.
* Added template graphic for Akai APC Mini courtesy of Guy
* Fixed Auto Next button in Data Sources not working after multiple toggles
* Fixed Wipe transition not showing cropped overlays correctly
thanks 11 users thanked admin for this useful post.
stigaard on 1/5/2017(UTC), doggy on 1/5/2017(UTC), sinc747 on 1/5/2017(UTC), madness on 1/5/2017(UTC), corporatejames on 1/5/2017(UTC), ask on 1/6/2017(UTC), ON.tv Channels on 1/6/2017(UTC), PrepSpin on 1/7/2017(UTC), al4video on 1/12/2017(UTC), scottyp on 1/24/2017(UTC), vijay6672 on 1/30/2017(UTC)
#6 Posted : Monday, January 23, 2017 11:58:10 AM(UTC)
18.0.0.61
* NEW Safe Areas added to Preview and Input Settings. To see the options click the new Safe Areas icon in the top right hand corner of the Preview title bar.
* Added support for X-keys XK-3 and XK-12 pedal/switch controllers
* Improved downscaling quality, for example 4K to HD.
* Fixed a couple of bugs with RTSP reconnections causing problems with Instant Replay.
* Fixed bug with ActiveInput/PreviewInput shortcuts not selecting the correct input when using these by Name in the API.
* Changing MultiView overlays within an Input in Output will now toggle auto audio and start/stop playback as settings allow.
* Fixed cropping not resetting when clicking Reset Position in a Virtual Set layer
* Fixed new preset not clearing local activators
* Fixed display names on activators list showing out of date information
thanks 18 users thanked admin for this useful post.
DWAM on 1/23/2017(UTC), Len56 on 1/23/2017(UTC), corporatejames on 1/23/2017(UTC), stigaard on 1/23/2017(UTC), madden64freak on 1/23/2017(UTC), ask on 1/23/2017(UTC), al4video on 1/23/2017(UTC), ON.tv Channels on 1/24/2017(UTC), SHMD on 1/24/2017(UTC), jip on 1/24/2017(UTC), scottyp on 1/24/2017(UTC), GeorgeR on 1/24/2017(UTC), Video Dave on 1/25/2017(UTC), Gary-WSN on 1/25/2017(UTC), princemedia on 1/29/2017(UTC), vijay6672 on 1/30/2017(UTC), sinc747 on 1/30/2017(UTC), tonylightfoot on 1/30/2017(UTC)
#7 Posted : Monday, January 30, 2017 3:57:06 AM(UTC)
18.0.0.63
* Added IBM Cloud Video Streaming Destination
* Updated NDI to latest updates
* Fixed lockup issue with RTSP reconnects while MultiView Output is active
* Added Grid 3 option to Safe Areas
thanks 9 users thanked admin for this useful post.
vijay6672 on 1/30/2017(UTC), sinc747 on 1/30/2017(UTC), Len56 on 1/30/2017(UTC), corporatejames on 1/30/2017(UTC), tonylightfoot on 1/30/2017(UTC), Video Dave on 1/31/2017(UTC), madness on 1/31/2017(UTC), pba on 1/31/2017(UTC), Amokka on 2/7/2017(UTC)
#8 Posted : Wednesday, February 8, 2017 3:50:55 AM(UTC)
18.0.0.64
* JLCooper ES SloMo J USB controller support
Buttons, T-Bar and Jog/Shuttle can be programmed to call any vMix shortcut
vMix includes a shortcut template for common replay controls including the ability to use the Num Pad
to type numbers into any vMix text field such as the Replay Play By ID option
* Replay Fast Forward / Rewind support through shortcuts
* Replay Shortcuts: ReplayPlay, ReplayPause, ReplayPlayForward, ReplayPlayBackward, ReplayFastForward, ReplayFastBackward
* Replay Activators: ReplayPlaying, ReplayACameraX, ReplayBCameraX
* New List Shortcut: ListShowHide
* Fixed bug with Arduino Mega used with Tally Lights
(To enable support, disable vMix Control Surface under Settings -> Options)
* Fixed "Use first row as column names" missing from Google Sheets data source
thanks 10 users thanked admin for this useful post.
stigaard on 2/8/2017(UTC), dasmedienatelier on 2/8/2017(UTC), sinc747 on 2/8/2017(UTC), Cpilcher on 2/8/2017(UTC), madness on 2/8/2017(UTC), corporatejames on 2/8/2017(UTC), alpha6 on 2/8/2017(UTC), pba on 2/8/2017(UTC), ask on 2/9/2017(UTC), vijay6672 on 2/9/2017(UTC)
#9 Posted : Thursday, February 9, 2017 2:54:21 AM(UTC)
18.0.0.65
* Fixed JLCooper detection causing problems on some systems
* Fixed vMix may freeze on closing after X-Keys has been disconnected
thanks 7 users thanked admin for this useful post.
stigaard on 2/9/2017(UTC), sinc747 on 2/9/2017(UTC), ask on 2/9/2017(UTC), vijay6672 on 2/9/2017(UTC), ON.tv Channels on 2/9/2017(UTC), madness on 2/9/2017(UTC), corporatejames on 2/10/2017(UTC)
