18.0.0.56
* Fixed bug in NDI that may cause freezing when loading presets with NDI sources that are offline * Fixed NDI output crash bug on old AMD systems that do not support it. NDI will now automatically deactivate on those systems to prevent the problem.
 3 users thanked admin for this useful post.
18.0.0.57
* Fixed an error when playing back Instant Replay events with only Mark In set
18.0.0.58
* NDI quality fixes and performance improvements * Added beta JSON data source * Added Activators support for Novation Launchpad MK2 LED buttons * Added workaround for bug in latest AMD Radeon drivers * Added generic graphic for X-keys and MIDI to Shortcuts Templates window * Fix for Magewell inputs showing up blank when multiple cards are installed * Fixed PreviewInput/ActiveInput shortcuts not working with Input names in API
 13 users thanked admin for this useful post.
ON.tv Channels on 12/11/2016(UTC), TV97 on 12/11/2016(UTC), BETech on 12/11/2016(UTC), Rinsky on 12/11/2016(UTC), vijay6672 on 12/12/2016(UTC), sinc747 on 12/12/2016(UTC), Stavlin on 12/13/2016(UTC), madness on 12/13/2016(UTC), xaver on 12/14/2016(UTC), SHMD on 12/23/2016(UTC), vadim_d on 12/25/2016(UTC), DWAM on 1/4/2017(UTC), scottyp on 1/24/2017(UTC)
18.0.0.59
* New "Automatically end stream" checkbox added to Facebook Settings. This will end the stream immediately after clicking Stop or closing vMix.
* Added higher bitrate AAC audio options for MP4 recording using a new improved encoder This should improve "transient artefacts" with some microphones
* Multiple X-Keys channels are now sorted manually by vMix instead of relying on Windows sorting which may change when unplugging USB devices. * Multiple displays are now sorted manually by vMix instead of relying on Windows sorting which may change depending on when the monitors turn on during boot up.
* Added template graphic for Akai APC Mini courtesy of Guy
* Fixed Auto Next button in Data Sources not working after multiple toggles * Fixed Wipe transition not showing cropped overlays correctly
 11 users thanked admin for this useful post.
stigaard on 1/5/2017(UTC), doggy on 1/5/2017(UTC), sinc747 on 1/5/2017(UTC), madness on 1/5/2017(UTC), corporatejames on 1/5/2017(UTC), ask on 1/6/2017(UTC), ON.tv Channels on 1/6/2017(UTC), PrepSpin on 1/7/2017(UTC), al4video on 1/12/2017(UTC), scottyp on 1/24/2017(UTC), vijay6672 on 1/30/2017(UTC)
18.0.0.61
* NEW Safe Areas added to Preview and Input Settings. To see the options click the new Safe Areas icon in the top right hand corner of the Preview title bar. * Added support for X-keys XK-3 and XK-12 pedal/switch controllers * Improved downscaling quality, for example 4K to HD. * Fixed a couple of bugs with RTSP reconnections causing problems with Instant Replay. * Fixed bug with ActiveInput/PreviewInput shortcuts not selecting the correct input when using these by Name in the API. * Changing MultiView overlays within an Input in Output will now toggle auto audio and start/stop playback as settings allow. * Fixed cropping not resetting when clicking Reset Position in a Virtual Set layer * Fixed new preset not clearing local activators * Fixed display names on activators list showing out of date information
 18 users thanked admin for this useful post.
DWAM on 1/23/2017(UTC), Len56 on 1/23/2017(UTC), corporatejames on 1/23/2017(UTC), stigaard on 1/23/2017(UTC), madden64freak on 1/23/2017(UTC), ask on 1/23/2017(UTC), al4video on 1/23/2017(UTC), ON.tv Channels on 1/24/2017(UTC), SHMD on 1/24/2017(UTC), jip on 1/24/2017(UTC), scottyp on 1/24/2017(UTC), GeorgeR on 1/24/2017(UTC), Video Dave on 1/25/2017(UTC), Gary-WSN on 1/25/2017(UTC), princemedia on 1/29/2017(UTC), vijay6672 on 1/30/2017(UTC), sinc747 on 1/30/2017(UTC), tonylightfoot on 1/30/2017(UTC)
18.0.0.63
* Added IBM Cloud Video Streaming Destination * Updated NDI to latest updates * Fixed lockup issue with RTSP reconnects while MultiView Output is active * Added Grid 3 option to Safe Areas
 9 users thanked admin for this useful post.
18.0.0.64
* JLCooper ES SloMo J USB controller support Buttons, T-Bar and Jog/Shuttle can be programmed to call any vMix shortcut vMix includes a shortcut template for common replay controls including the ability to use the Num Pad to type numbers into any vMix text field such as the Replay Play By ID option * Replay Fast Forward / Rewind support through shortcuts * Replay Shortcuts: ReplayPlay, ReplayPause, ReplayPlayForward, ReplayPlayBackward, ReplayFastForward, ReplayFastBackward * Replay Activators: ReplayPlaying, ReplayACameraX, ReplayBCameraX * New List Shortcut: ListShowHide
* Fixed bug with Arduino Mega used with Tally Lights (To enable support, disable vMix Control Surface under Settings -> Options)
* Fixed "Use first row as column names" missing from Google Sheets data source
 10 users thanked admin for this useful post.
18.0.0.65
* Fixed JLCooper detection causing problems on some systems * Fixed vMix may freeze on closing after X-Keys has been disconnected
 7 users thanked admin for this useful post.
