Joined: 5/9/2016(UTC) Posts: 37 Location: Atlanta, GA
I know enough technical stuff to know how much I don't know! My current i7 laptop is old so I am shopping for a replacement.
There is so much info on the vMix forums that it would take weeks to read/comprehend it all.
I want to use vMix basic for two cameras and maybe an additional USB3.0 document camera. I use Magewell adapters to convert SDI to USB3.0. Everything goes through a powered USB3.0 hub.
I do not stream now but maybe down the road.
What are the minimum recommendations for the processor and graphics card. If someone would recommend a laptop or portable computer I really would appreciate it!
You have been a member since:: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ Braindead Exactly how old is your laptop? You just might be able get by with it for the time being while you do more research. In a lot of ways, it comes down to what your overall needs are and what your budget is. vMix has just started listing "Reference" systems on their web site which give a general idea of what is basically needed for average/typical use, and as for laptops, it would appear the gaming line of products is recommended: http://www.vmix.com/prod...ce-systems.aspx#sapphireHope that helps some. Ice
Specs for my ASUS G74SX: System Intel® Core™ i7-2670QM CPU @ 2.20GHZ @.20GHZ RAM 12GB Windows 10 64bit Geforce GTX 560m Whatcha think???
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Braindead wrote:Specs for my ASUS G74SX: System Intel® Core™ i7-2670QM CPU @ 2.20GHZ @.20GHZ RAM 12GB Windows 10 64bit Geforce GTX 560m Whatcha think???
I think that should work for your initial setup...give it a try first...
Quote:Specs for my ASUS G74SX: System Intel® Core™ i7-2670QM CPU @ 2.20GHZ @.20GHZ RAM 12GB Windows 10 64bit Geforce GTX 560m Whatcha think??? How many USB 3.0 ports do you have? ASUS online specs list 1.
Only one USB 3.0 port. I use a powered USB 3.0 hub.
Joined: 2/9/2013(UTC) Posts: 264 Location: Katy, Texas
USB 3.0 has total bandwidth of 5Gbps. A single HD-SDI feed at 720p or 1080i is 1.5Gbps and a 3G-SDI feed of 1080p is 3Gbps. If using 720p or 1080i, you might get all 3 cameras to work on your current setup. The only way to know for sure is to test it, but don't be disappointed if it doesn't work.
 1 user thanked Kelvin for this useful post.
Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
Kelvin wrote:USB 3.0 has total bandwidth of 5Mbps. A single HD-SDI feed at 720p or 1080i is 1.5Mbps and a 3G-SDI feed of 1080p is 3Mbps. If using 720p or 1080i, you might get all 3 cameras to work on your current setup. The only way to know for sure is to test it, but don't be disappointed if it doesn't work. Just to clarify, I think the units given should be Gbps instead of Mbps. It's pretty common to say that USB3.0 has the bandwidth of 5 Gbps. E.g. take a look at this simple scheme of the bandwidth for some common technologies: http://www.extremetech.c...2015/06/Thunderbolt1.png
Thanks for the corrections. I fixed the original post.
The ASUS are generally a great choice.
ASUS ROG G751JY-VS71 17.3 inch 1920×1080 Intel Core i7-4720HQ 2.6 GHz 1TB 7200RPM 16GB DDR3 GeForce GTX 980M 4GB DDR5 More
Look for something like this: http://www.vmix.com/prod...ce-systems.aspx#sapphireUSB 3 Ports 2 or more + Thunderbolt 3 = Good, because you can add more USB 3 (with a thunderbolt 3 dock) or Thunderbolt Capture devices. 512GB SSD = Nice NVIDIA GTX 1060 = Awesome Brand = Doesn't matter a great deal to me they all source parts from Intel, Foxconn and friends so cheaper = lower quality fittings generally.
Speegs wrote:Look for something like this: http://www.vmix.com/prod...ce-systems.aspx#sapphireUSB 3 Ports 2 or more + Thunderbolt 3 = Good, because you can add more USB 3 (with a thunderbolt 3 dock) or Thunderbolt Capture devices. 512GB SSD = Nice NVIDIA GTX 1060 = Awesome Brand = Doesn't matter a great deal to me they all source parts from Intel, Foxconn and friends so cheaper = lower quality fittings generally. I bought a MSI laptop that meets all the criteria. Big sucker but not too heavy.
