Thanks: 46 times Was thanked: 2 time(s) in 2 post(s)
Hi Martin I have a few little problems A major project after I came out on video MUTE try to do everything properly and checked every time and still the problem.
1 - XP Pro sp3 all updated 2-2 Camera Canon GL1 and GL2x, 1394 firewire cable 3 - The audio audimixer properly marked and check the box to the mix and nothing worked. 4 - Auxiliary output and input will coleque a jumper wire 5 - Each frame of the camera display of the audio appeared in green option, but when I change CHAMBER TO REMOVE ONLY, that occurs in cad cam movement that removed the green. 6 - video alpha channels is always slow PAUSE only, and are more imprtantes arrangements to give life to the project. 7 - What is the recommended number for the heating of the CPU? Martin you recommend? 8 - I beg the solution for MOV files that are frozen or not working, there are 2 types of trnsparencias 1 - Grey trasnparente, 2 - Black also transparent but both do not work.
I'm being asked in several places soft. in Latin churches, and small events because they have seen everything by hand and taking it all goes very good and the better the sound quality AVI and MPEG 2.
And the question is for when more or less, or - so that time will leave the V9 with all working vercion correctly, that month? Martin Thanks for your patience
PD Could you make a post just to support this type of situation or Tnks. continuing to learn from mistakes and solutions
Spanish copy for you to use your favorite translator.
======================================================================= Hola Martin Tengo unos problemitas despues de un importante proyecto me salio MUDO el video trate de hacer todo correctamente y lo chequeaba cada momento y aun asi el problema .
1- XP Pro sp3 todo actualizado 2- 2 Camaras Canon GL1 y GL2x , por cable firewire 1394 3- El audimixer marcaba correctamente el audio y seleccione el cuadro para que funcionara la mescla y nada . 4- La salida auxiliar y entrada le coleque un cable de puente 5- Cada cuadro de display de la camara aparecia el audio en opcion verde , PERO CUANDO CAMBIABA CAMARA SE QUITA SOLO , eso pasa en cad movimiento de camara que quitaba lo verde . 6- videos CANAL ALFA se queda pausado siempre PAUSA solo , y son los arreglos mas imprtantes para darle vida al proyecto . 7- Cual es el numero recomendado para el calentamiento de el CPU ? que recomiendas Martin ? 8- Te ruego la solucion para los archivos MOV que se congelan o no trabajan , hay 2 tipos de trnsparencias 1- Gris trasnparente , 2- Negro Tambien transparente pero ambos no funcionan .
Me estan pidiendo en varios lugares el soft. en iglesias Latinas , y eventos pequeños porque han visto que ya teniendo todo a mano todo sale muy bueno y lo mejor es la buena calidad en AVI y MPEG 2 .
Y la pregunta es para cuando mas o menos o - para que tiempo saldra la vercion V9 con todo trabajando correctamente , que mes ? Gracias Martin por tu paciencia
PD Podrias hacer un post solo para Soporte o este tipo de situacion Tnks . permanente para aprender de los errores y soluciones
copia en Español para que uses tu preferido Traductor .
Joined: 1/13/2010(UTC) Posts: 5,336  Location: Gold Coast, Australia Was thanked: 4736 time(s) in 1625 post(s)
I think one of things you have referred to is the quicktime loop problem. This is a known issue that will be fixed in v9. As for the other issues, I am having trouble interpreting the other questions. Could you explain the issues you are having as simply as possible.
Martin vMix
OK USE GOOGLE TRASLATOR U OTRO Same tknks
Rank: Guest
Groups: Guests
hi, elchapin (hola :D)
pienso que te puedo ayudar con esta traducción, a mi tambien me he confundido un rato... si algo no está bien en la traducción por favor di-me-lo... salutos, melody
Martin,
helping elchapin, please take a look on this translation if it can help you to understand... regards, melody.
Hi Martin I have some problems here after vmix used in a major project that went unsuccessfull, because I got no sound, tried to configure everything correctly and checking all the time if everything was OK, but the problem persisted.
1 - XP Pro SP3 update 2-2 Cameras Canon GL1 and GL2x, cable 1394 3 - The audio mixer marked correct values and started the mix but nothing worked. 4 - I connected a cable between the audio mixer and the PC 5 - the display of each camera showed the sound in a green option, but when I changed the camera in vmix the sound, in a green option, simply disappeared. 6 - the videos with alpha values are constantly paused, and they are giving more wealth to the production. 7 - What is the recommended temperature of CPU in your opinion Martin? 8 - I ask you, please, correct the problem with mov files that do not work or simply freeze 8.1 - transparent gray; 8.2 - black also transparent both do not work.
Several people are interested in the vmix and they look for information in the Latin churches and small events, because they saw that software is a very practical and that works quite well with AVI and MPEG 2.
and the question is: When is it planned to launch the new vmix v9? Thanks for your patience Martin
PD You could make a post just to tell us about new version time to launch. Thanks. I still learn from mistakes and solutions.
To record audio from audio mixer in vMix: 1. In Windows Control Panel, make sure correct input is selected in Sounds for Recording. 2. Set the correct Audio Device (sound card) in Recording Setup This will only record audio from audio mixer input. See here for more information: http://www.vmix.com.au/h...rdingAudiowithVideo.htmlPara grabar audio del mezclador de audio en vMix:
1. En Panel de control, que de entrada correcta esté seleccionada en sonido para la grabación. 2. Ajuste el dispositivo de audio adecuado (tarjeta de sonido) en Configuración de la grabación
Tenga en cuenta que esto sólo grabar el audio de entrada del mezclador de audio.
Consulte aquí para obtener más información:
Thanks for the help as always correct take all instructions step by step. The problem of translation will always think but there we settled slowly thanks HAPPY NEW YEAR'S PARTY!
