setup of recording MPEG-2, error in windows 8
 The MPEG-2 Encoder requires Windows Media Center to be installed on this version of Windows
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Yes, that is correct. You will need to install the Media Center Pack which is now an optional purchase for Windows 8. Search google for the Media Center Pack for Windows 7 for more information.
admin wrote:Yes, that is correct. You will need to install the Media Center Pack which is now an optional purchase for Windows 8. Search google for the Media Center Pack for Windows 7 for more information. thanks martin. is there another solution that vmix works well in windows 8 without media center pack? hopefully in next versions, you fix it. regards
This is not a bug, Microsoft moved MPEG-2 recording support to the Windows 8 Media Center Pack. You can install the media center pack or choose another recording option such as AVI.
Martin vMix
Joined: 11/15/2010(UTC) Posts: 99  Location: Jamaica Thanks: 23 times Was thanked: 17 time(s) in 14 post(s)
admin wrote:This is not a bug, Microsoft moved MPEG-2 recording support to the Windows 8 Media Center Pack. You can install the media center pack or choose another recording option such as AVI.
Martin vMix Hi Martin good job as usual, question for you, i notice whenever i set the recording in setup to reset/restart every 10 min there is a number of drop or lost frames in the video clips. ex. if someone is speaking and the recording restarts the the sentence or word gets cut off and throws the sentence off in a bad way. Is there a way to setup vmix so i can have those clips cut without loosing the flow of what is being said or sang?
Martin vMix ok thanks martin. Now I've installed windows 8 media center pack. and now vimix works well.
