fcienfuegos
#1 Posted : Tuesday, November 13, 2012 2:10:20 PM(UTC)
fcienfuegos
I am trying to open an MP4 video file and I'm getting an error message asking me to install Haali Media Splitter, which I did and I still can't open the file. Your help is greatly appreciated.
Thank you
Egriswold
#2 Posted : Tuesday, November 13, 2012 2:38:40 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
Thank you
Have you tried VLC ?
fcienfuegos
#3 Posted : Tuesday, November 13, 2012 2:41:21 PM(UTC)
fcienfuegos
Egriswold wrote:
Thank you
I did, but I want to mix two video files, I don't think VLC can do that but I was under the impression that vMix can.
Ernest Król
#4 Posted : Thursday, November 15, 2012 4:33:54 PM(UTC)
Ernest Król
hi,
You should install Matroska Splitter http://haali.su/mkv/
I had the same problem, and that was a solution :)
#5 Posted : Friday, November 16, 2012 9:22:35 AM(UTC)
Was thanked: 4726 time(s) in 1618 post(s)
As mentioned the Haali Media Spliter is all that is required to play back mp4 files under Windows 7.
If you are using Windows XP I would recommend upgrading to 7/8 or you will need a 3rd party H.264 codec installed.
