macgiver76
#1 Posted : Monday, November 14, 2016 5:51:21 AM(UTC)
macgiver76
I can not find the shortcuts to set "Send this audio input to master", "Send this audio input to Bus A" Send this audio input to Bus B ".
I would like to set these functions for each input and control them with Akay APC 40 MKII.
Accidentally making a wrong step?
Thank you
#2 Posted : Monday, November 14, 2016 8:56:17 PM(UTC)
Was thanked: 4727 time(s) in 1619 post(s)
Use the "AudioBus" shortcut function, setting the value to M, A or B
This will create a toggle, if you only want a button to turn on or off, use AudioBusOn/Off.
macgiver76 on 11/15/2016(UTC)
macgiver76
#3 Posted : Tuesday, November 15, 2016 2:34:51 PM(UTC)
macgiver76
Thank You for response.
There is also a way to create a shortcut for the "Separate Mono" function on a single entry?
Thank you!
Joeboe
#4 Posted : Thursday, December 16, 2021 9:59:36 PM(UTC)
Joeboe
I do not quite understand...I tried many times, but still cannot get this to work....is this in the General Settings, that I can do this? because I just cannot get to toggle on/off my Buses....I get the Master to toggle, but not A,B, or any other to work....
raugert
#5 Posted : Thursday, December 16, 2021 11:49:17 PM(UTC)
raugert
Canada
Hi Joeboe,
If I understand correctly, you are trying to turn the actual "Bus X" On/Off ? In order to do that, use the "BusXAudio" command and enter the selected Bus in the Value field. That will turn the complete Bus On/Off. The "AudioBus" command refers to the Bus of a particular Input.
Joeboe
#6 Posted : Friday, December 17, 2021 4:14:10 AM(UTC)
Joeboe
I got it to work....I had things linked to something else...all is well now....and the tally is working as well, so I know which Bus I am using.....The first method is what I needed
Thanks all...
