Shortcut don't found for Audio Master - Bus A - Bus B
Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Hello, I can not find the shortcuts to set "Send this audio input to master", "Send this audio input to Bus A" Send this audio input to Bus B ". I would like to set these functions for each input and control them with Akay APC 40 MKII. Accidentally making a wrong step? Thank you
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Use the "AudioBus" shortcut function, setting the value to M, A or B This will create a toggle, if you only want a button to turn on or off, use AudioBusOn/Off.
Thank You for response. There is also a way to create a shortcut for the "Separate Mono" function on a single entry? Thank you!
Originally Posted by: admin  Use the "AudioBus" shortcut function, setting the value to M, A or B This will create a toggle, if you only want a button to turn on or off, use AudioBusOn/Off. I do not quite understand...I tried many times, but still cannot get this to work....is this in the General Settings, that I can do this? because I just cannot get to toggle on/off my Buses....I get the Master to toggle, but not A,B, or any other to work....
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
Hi Joeboe,
If I understand correctly, you are trying to turn the actual "Bus X" On/Off ? In order to do that, use the "BusXAudio" command and enter the selected Bus in the Value field. That will turn the complete Bus On/Off. The "AudioBus" command refers to the Bus of a particular Input.
I got it to work....I had things linked to something else...all is well now....and the tally is working as well, so I know which Bus I am using.....The first method is what I needed
Thanks all...
