ask
#1 Posted : Saturday, November 12, 2016 12:09:37 AM(UTC)
ask
Is there a way to specify which overlay will appear on top of another if you layer them on the screen? An example is to have a scoreboard displayed on the screen, then have a sponsors name or message slide up behind it and appear over the top for a period of time and then disappear.
#2 Posted : Saturday, November 12, 2016 1:01:34 AM(UTC)
@ ask
Do you mean "a way to re-order" the overlay channel?
Because they are already layered progressively, and I don't think that is about to change...
If I understand you correctly, you should be able to accomplish what you describe in an automated way with "Triggers" or alternatively manually with mouse clicks or "shortcuts".
Can you elaborate further?
ask
#3 Posted : Saturday, November 12, 2016 3:13:25 AM(UTC)
ask
I suppose re-odering might be a solution. I thought like you the they were progressive. That 1 would overlay on 2 and both over 3, or vis versa, but that does not seem to happen in a consistent way. It could simply be that I haven't grasped the logic of the layering, but I want to be able to bring in an overlay ---say no 1, and then whenever I click 2 know hat it will always appear behind the first overlay.
richardgatarski
#4 Posted : Saturday, November 12, 2016 4:05:45 AM(UTC)
richardgatarski
Maybe I am missing something here, but the layer ordering is: 1 is bottom, 2 on 1, 3 on 2, and 4 on 3 (and 2 and 1). I have never found any inconsistency in that...
So, if you want something to slide under, put that something in an Ovrrlay with a number below the Overlay above.
corporatejames
#5 Posted : Saturday, November 12, 2016 4:55:03 AM(UTC)
corporatejames
Need to design the way to you do the scoreboard/lowerthirds correctly. Chat to me about it next week.
Most of my designs all use the overlays for xaml depending on what is required.
I use overlay 2 when overlay 1 is active for scorebug and show +1 with animated flag over the top of the score for example.
This could be country flag when they score, after 1 sec it will animate out and overlay 2 will turn off.
Same with all the advertisements banners and stats popups which slide up from the scorebug
Overlay 4 is the top layer
[url=ASN GFX StatsDemo - update with Score by Qtr]https://www.youtube.com/watch?v=mWm5IzpPJec[/url]
ask
#6 Posted : Saturday, November 12, 2016 5:26:47 AM(UTC)
ask
Thanks all
#7 Posted : Saturday, November 12, 2016 2:11:39 PM(UTC)
@ ask
When I said 'layered progressively', that is exactly what I meant, 1 is at the bottom progressing to 4 (5 in MultiView) on top, and as Richard says, that has always been consistent. Once you understand all those dynamics and how vMix handles them, it's just a matter of planning out appropriately.
