Thanks: 5 times Was thanked: 8 time(s) in 8 post(s)
Hi I found bug with shortcuts and adding virtual inputs. When you have more than 3 shortcuts, assigned to input number. Third shortcut input number change when you add virtual input. Look at video: - Jan edit: I testet it on version 17 and 18.0.0.52
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
kol0 wrote:Hi I found bug with shortcuts and adding virtual inputs. When you have more than 3 shortcuts, assigned to input number. Third shortcut input number change when you add virtual input. Look at video: - Jan edit: I testet it on version 17 and 18.0.0.52 It doesnt matter if they are assigned to input number. I also use shortcuts for basketball and when I add for example camera input all shortcuts mess up and doesn't point on scoreboard, it points to new input, the every one and I need to change again to what input are the shortcut buttons. Everything stays same only need to change what button is pointing to
Siroki wrote:kol0 wrote:Hi I found bug with shortcuts and adding virtual inputs. When you have more than 3 shortcuts, assigned to input number. Third shortcut input number change when you add virtual input. Look at video: - Jan edit: I testet it on version 17 and 18.0.0.52 It doesnt matter if they are assigned to input number. I also use shortcuts for basketball and when I add for example camera input all shortcuts mess up and doesn't point on scoreboard, it points to new input, the every one and I need to change again to what input are the shortcut buttons. Everything stays same only need to change what button is pointing to When you are setting the shortcut up you can assign them to either an input number or to the name of the input. to do the latter untick the Assign Shortcut to Input Number check box. Refer here: http://www.vmix.com/help...dex.htm?AddShortcut.html
ask wrote:Siroki wrote:kol0 wrote:Hi I found bug with shortcuts and adding virtual inputs. When you have more than 3 shortcuts, assigned to input number. Third shortcut input number change when you add virtual input. Look at video: - Jan edit: I testet it on version 17 and 18.0.0.52 It doesnt matter if they are assigned to input number. I also use shortcuts for basketball and when I add for example camera input all shortcuts mess up and doesn't point on scoreboard, it points to new input, the every one and I need to change again to what input are the shortcut buttons. Everything stays same only need to change what button is pointing to When you are setting the shortcut up you can assign them to either an input number or to the name of the input. to do the latter untick the Assign Shortcut to Input Number check box. Refer here: http://www.vmix.com/help...dex.htm?AddShortcut.html I know that Try both but sometimes it mess up
Joined: 8/24/2016(UTC) Posts: 8 Location: Memphis, TN - USA
I have noticed the same problem as well. Sometimes the shortcuts do not stay with the input (even with Assign to number box UNCHECKED) and all shortcuts get pointed to a different input. Is there not a way to do a GLOBAL edit so that I can select all shortcuts and change the input instead of having to change each one individually?
