kol0
#1 Posted : Thursday, November 10, 2016 12:53:59 PM(UTC)
kol0
Was thanked: 8 time(s) in 8 post(s)
Hi
I found bug with shortcuts and adding virtual inputs.
When you have more than 3 shortcuts, assigned to input number.
Third shortcut input number change when you add virtual input.
Look at video:
- Jan
edit: I testet it on version 17 and 18.0.0.52
Siroki
#2 Posted : Thursday, November 10, 2016 6:48:06 PM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
kol0 wrote:
Hi
Look at video:
- Jan
It doesnt matter if they are assigned to input number. I also use shortcuts for basketball and when I add for example camera input all shortcuts mess up and doesn't point on scoreboard, it points to new input, the every one and I need to change again to what input are the shortcut buttons. Everything stays same only need to change what button is pointing to
ask
#3 Posted : Thursday, November 10, 2016 7:27:20 PM(UTC)
ask
Siroki wrote:
kol0 wrote:
Hi
Look at video:
- Jan
When you are setting the shortcut up you can assign them to either an input number or to the name of the input. to do the latter untick the Assign Shortcut to Input Number check box.
Refer here: http://www.vmix.com/help...dex.htm?AddShortcut.html
Siroki
#4 Posted : Friday, November 11, 2016 4:36:12 AM(UTC)
Siroki
ask wrote:
Siroki wrote:
kol0 wrote:
Hi
Look at video:
- Jan
I know that
Try both but sometimes it mess up
Gary-WSN
#5 Posted : Friday, November 11, 2016 1:32:07 PM(UTC)
Gary-WSN
I have noticed the same problem as well. Sometimes the shortcuts do not stay with the input (even with Assign to number box UNCHECKED) and all shortcuts get pointed to a different input. Is there not a way to do a GLOBAL edit so that I can select all shortcuts and change the input instead of having to change each one individually?
