	Instant Replay
	Probably bug in instant replay audio strip configuration?
  Thanks: 10 times Was thanked: 33 time(s) in 28 post(s)
                Hi
  Version 17.0.0.112
  If I add an instant replay input to my preset, one audio strip is added to the audio mixer (for channel A).
  In audio strip of instant replay, if I press the speaker icon to mute/unmute audio, the audio buttons of both inputs channel A and B are changing from green to black and vice versa. Sounds logical to me.
  In audio strip of instant replay, if I press the "Automatically Mix Audio" icon, only the "Automatically Mix Audio" setting of input channel A is changing. Input channel B is not changing. Sounds not logical to me. As I would expect, it should have the same behaviour like the mute/unmute button and change the setting on both channels.
  Regards, Patrick
 Joined: 5/20/2015(UTC) Posts: 492   Location: Copenhagen, Denmark Thanks: 411 times Was thanked: 102 time(s) in 79 post(s)
                pm wrote: In audio strip of instant replay, if I press the "Automatically Mix Audio" icon, only the "Automatically Mix Audio" setting of input channel A is changing. Input channel B is not changing. Sounds not logical to me. As I would expect, it should have the same behaviour like the mute/unmute button and change the setting on both channels.
  As I have wrapped my head around understanding replay channel A and B, the case is, that whenever you want to send a replay to the output, it will always use channel A. The second channel is for previewing a secondary camera angle to your producer. Therefore, you should not worry about audio on channel B. I hope that this made some sense :-)
                That was also my first intention.
  But during playing around (testing new workflows) with instant replay, i suddenly had unexpected audio from instant replay on the master channel.
  That's what I did: - Playing replay event cam1 with channel A to output. - Changing channel B to cam2 and set channel B to preview. - Fade preview to output. - Because "automatically mix audio" was set in input settings channel B, I suddenly had audio on the master output altough I disabled "automatically mix audio" before in replay audio strip.
  So the settings in channel B are relevant in some cases...
	Instant Replay
