Recording timed out waiting for first frame error
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I did a clean Windows 7 32bit install with vMix 17.0.0.112 and sometimes when vMix is starting I get this error:
Recording timed out waiting for first frame error / Streaming.start.buffer_WFF (I did send error report)
(I do not use recording, when I click close, vMix is working OK)
What is going wrong?
I also noticed this application warning when vMix is started, but I understand from older threads that it can be ignored:
.Net runtime
Log Name: Application Source: .NET Runtime Date: 6-11-2016 14:39:25 Event ID: 1000 Task Category: None Level: Warning Keywords: Classic User: N/A Computer: STREAM-PC Description: .NET Runtime version 2.0.50727.5420 - This application is using the HMAC-SHA-384 or HMAC-SHA-512 keyed hash algorithm. The implementation of these algorithms were updated in service pack 1 of .NET Framework 2.0 and by default do not produce results consistent with the unserviced versions of the classes. For more information about the changes to the algorithms and how to disable this warning message please see the release notes for service pack 1. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name=".NET Runtime" /> <EventID Qualifiers="0">1000</EventID> <Level>3</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2016-11-06T13:39:25.000000000Z" /> <EventRecordID>628</EventRecordID> <Channel>Application</Channel> <Computer>STREAM-PC</Computer> <Security /> </System> <EventData> <Data>.NET Runtime version 2.0.50727.5420 - This application is using the HMAC-SHA-384 or HMAC-SHA-512 keyed hash algorithm. The implementation of these algorithms were updated in service pack 1 of .NET Framework 2.0 and by default do not produce results consistent with the unserviced versions of the classes. For more information about the changes to the algorithms and how to disable this warning message please see the release notes for service pack 1.</Data> </EventData> </Event>
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
This error means the graphics card has stopped responding. In the error report there are a number of other programs running including radmin, so try uninstalling that first as it can interfere with the graphics.
Then also try:
1. Making sure latest Nvidia driver is installed 2. Setting Windows 7 to "Aero" theme
I've set aero theme and desktop composition is enabled, but I've disabled transparent glass and aero peek to save cpu, should I enable them?
Are you starting the stream through some kind of script? Streaming needs vMix to be fully initialized before starting, so maybe it only happens when it is started too quickly?
Yes, I'm using a script that is waiting for 15 seconds, but sometimes vMix is starting realy slow. I will increase it to 30 seconds.
wwdv wrote:Yes, I'm using a script that is waiting for 15 seconds, but sometimes vMix is starting realy slow. I will increase it to 30 seconds. You may need longer than that depending on the number of inputs that are being loaded and the type of inputs. I would give it a minute or two to be safe.
