5 Pages<12345>
coolnetgr
#41 Posted : Tuesday, November 1, 2016 6:34:50 AM(UTC)
coolnetgr
ask wrote:
vfxblend wrote:
amonerdj wrote:
any tutorial for using?
Sure uploading tutorial
Hi, Did you upload the tutorial? If so where?
Also would it be possible to add a check for the JRE and VLC 64 bit versions at startup? At the moment the program simply hangs without any indication of what is missing.
Andrew
Here is the tutorial:
attilio18
#42 Posted : Friday, November 4, 2016 8:24:53 AM(UTC)
attilio18
Hi, I just tested 'vmixtask'. I like windows 7 pro 64 system, vmix17. setting the time the videos started well .. but when opened in Vmix video appears to be jerky and out of sync audio and video. The video format is: * .mpeg 1280x720 50p. I apologize for my spoken English .. but I only know the Italian language ..
vfxblend
#43 Posted : Friday, November 4, 2016 4:03:33 PM(UTC)
vfxblend
Was thanked: 32 time(s) in 10 post(s)
Does the video play smooth in vMixTask?
is it a particular video or all videos?
Try and play the video manually in vmix
attilio18
#44 Posted : Saturday, November 5, 2016 10:47:51 AM(UTC)
attilio18
hi,
I respected all parameters.
latest version of VLC and java. when 'Task' recalls the video one can see a preview ..
but when prompted by Vmix jerky and out syncronized audio ..
maybe it depends on my PC not being so powerful ..
if you load the same video only Vmix, you see well and in perfect sync.
HJM1
#45 Posted : Sunday, November 6, 2016 8:53:52 AM(UTC)
HJM1
Is there also a possibility to schedule for 7 days? We broadcast only one day in a week therefore we have to make a schedule for the hole week.
Thanks, HJM1
Maximus
#46 Posted : Wednesday, November 9, 2016 2:26:29 PM(UTC)
Maximus
Hi vfxblend,
Any further updates on this package?
Maxi
vfxblend
#47 Posted : Thursday, November 10, 2016 8:13:41 AM(UTC)
vfxblend
Maximus wrote:
Hi vfxblend,
Maxi
Sure Maxi, there is a major update
sorry for my silence, iv been busy rewriting the whole code in c#
i am done now recording a tutorial for it now
the new update includes:
1. Whole new Interface
2. Ability to trim in and out of a clip
3. Mute button for both displays
4. Ability Shuffle selected clips
5. Ability to Duplicate a clip
6. Adding Clips now appends after selected clip
7. Open dialog now supports search and displays thumbnails
8. New Column added for instant retime
9. New color scheme to identify TAGS, playing, Aired and Ready
vfxblend
#48 Posted : Thursday, November 10, 2016 8:47:58 AM(UTC)
vfxblend
thanks 2 users thanked vfxblend for this useful post.
vijay6672 on 11/10/2016(UTC), J'chap on 11/15/2016(UTC)
Maximus
#49 Posted : Friday, November 11, 2016 12:19:07 AM(UTC)
Maximus
Good move to C#. Improvements sound awesome. I will download and give it a try. Should I uninstall original version or install over the top?
Maxi
stevespaw
#50 Posted : Friday, November 11, 2016 11:58:16 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
This sounds great, I look forward to trying it out,
Just to make this thread work better for you, if you could make your announcements and information by just editing your first post with updated information.
Great example is the UTC thread. http://forums.vmix.com/default.aspx?g=posts&t=6468
I look forward to seeing the info there and any tutorials etc.
Thanks for your work on this it look great,
Steve
num127
#51 Posted : Sunday, November 13, 2016 4:38:57 AM(UTC)
num127
First of all, I want to thank you build a very good program I encourage you to develop it further.
Try to use I have the following problem.
1. It does not support files written in languages ​​of Thailand.
2. When the file is added at exactly the wrong hour. Make unavailable
3. Vmix are displayed on two channels simultaneously stumbling all files.
[img][/img]
num127 attached the following image(s):
num127
#52 Posted : Sunday, November 13, 2016 4:48:17 AM(UTC)
num127
I have proposed a solution for the installation. Then you do not have to install this for two window10 64 bit.
1.jre-8u111-windows-x64
2.vlc-2.2.4-win64
I can not send files I ask you to find it from google.
vfxblend
#53 Posted : Sunday, November 13, 2016 8:35:22 PM(UTC)
vfxblend
[img][/img]
number 2 and 3 have been solve in the upcoming release
cant you send an image of what the Thailand language looks like?
vfxblend
#54 Posted : Sunday, November 13, 2016 8:41:50 PM(UTC)
vfxblend
Steve
thank you steve for the insight
manojhadke
#55 Posted : Monday, November 14, 2016 3:44:57 AM(UTC)
manojhadke
plz give new update link...
num127
#56 Posted : Monday, November 14, 2016 4:51:51 AM(UTC)
num127
The top line is the correct language. The bottom line The display language is faulty
vfxblend
#57 Posted : Monday, November 14, 2016 5:43:38 AM(UTC)
vfxblend
ok, will look into the language
The link for the update will surely be available later today
thanks.
thanks 3 users thanked vfxblend for this useful post.
num127 on 11/14/2016(UTC), J'chap on 11/15/2016(UTC), vijay6672 on 11/15/2016(UTC)
sosparabolicas
#58 Posted : Tuesday, November 15, 2016 4:27:59 PM(UTC)
sosparabolicas
When will this downloadable version be available?
sosparabolicas
#59 Posted : Thursday, November 17, 2016 1:06:04 PM(UTC)
sosparabolicas
please new
brunolekid
#60 Posted : Thursday, November 17, 2016 3:56:47 PM(UTC)
brunolekid
Good evening !!!
This is a great job !!! i hope you will add the possibility to automatically removed aired items
on vmix timeline.
Also if we can create a group of tag.( ie grouptag1: overlay1+overlay2 are active , grouptag2: overlay2+overlay3 are active)
Regards
Guest (13)
5 Pages<12345>
