3rd Party Software and Development
vMixTask [A new Scheduler for vmix with automated overlays control]
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
ask wrote:vfxblend wrote:amonerdj wrote:any tutorial for using? Sure uploading tutorial Hi, Did you upload the tutorial? If so where? Also would it be possible to add a check for the JRE and VLC 64 bit versions at startup? At the moment the program simply hangs without any indication of what is missing. Andrew Here is the tutorial:
Hi, I just tested 'vmixtask'. I like windows 7 pro 64 system, vmix17. setting the time the videos started well .. but when opened in Vmix video appears to be jerky and out of sync audio and video. The video format is: * .mpeg 1280x720 50p. I apologize for my spoken English .. but I only know the Italian language ..
Thanks: 1 times Was thanked: 32 time(s) in 10 post(s)
attilio18 wrote:Hi, I just tested 'vmixtask'. I like windows 7 pro 64 system, vmix17. setting the time the videos started well .. but when opened in Vmix video appears to be jerky and out of sync audio and video. The video format is: * .mpeg 1280x720 50p. I apologize for my spoken English .. but I only know the Italian language .. Does the video play smooth in vMixTask? is it a particular video or all videos? Try and play the video manually in vmix
hi, I respected all parameters. latest version of VLC and java. when 'Task' recalls the video one can see a preview .. but when prompted by Vmix jerky and out syncronized audio .. maybe it depends on my PC not being so powerful .. if you load the same video only Vmix, you see well and in perfect sync.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Is there also a possibility to schedule for 7 days? We broadcast only one day in a week therefore we have to make a schedule for the hole week.
Thanks, HJM1
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
Hi vfxblend, Any further updates on this package?
Maxi
Maximus wrote:Hi vfxblend, Any further updates on this package?
Maxi Sure Maxi, there is a major update sorry for my silence, iv been busy rewriting the whole code in c# i am done now recording a tutorial for it now the new update includes: 1. Whole new Interface 2. Ability to trim in and out of a clip 3. Mute button for both displays 4. Ability Shuffle selected clips 5. Ability to Duplicate a clip 6. Adding Clips now appends after selected clip 7. Open dialog now supports search and displays thumbnails 8. New Column added for instant retime 9. New color scheme to identify TAGS, playing, Aired and Ready
 2 users thanked vfxblend for this useful post.
Good move to C#. Improvements sound awesome. I will download and give it a try. Should I uninstall original version or install over the top?
Maxi
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
vfxblend wrote:sorry for my silence, iv been busy rewriting the whole code in c# i am done now recording a tutorial for it now the new update includes:
1. Whole new Interface 2. Ability to trim in and out of a clip 3. Mute button for both displays 4. Ability Shuffle selected clips 5. Ability to Duplicate a clip 6. Adding Clips now appends after selected clip 7. Open dialog now supports search and displays thumbnails 8. New Column added for instant retime 9. New color scheme to identify TAGS, playing, Aired and Ready This sounds great, I look forward to trying it out, Just to make this thread work better for you, if you could make your announcements and information by just editing your first post with updated information. Great example is the UTC thread. http://forums.vmix.com/default.aspx?g=posts&t=6468 I look forward to seeing the info there and any tutorials etc. Thanks for your work on this it look great, Steve
First of all, I want to thank you build a very good program I encourage you to develop it further. Try to use I have the following problem. 1. It does not support files written in languages of Thailand. 2. When the file is added at exactly the wrong hour. Make unavailable 3. Vmix are displayed on two channels simultaneously stumbling all files. [img][/img] num127 attached the following image(s):  1478938824199.jpg (31kb) downloaded 1 time(s). 1478939001386.jpg (181kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
I have proposed a solution for the installation. Then you do not have to install this for two window10 64 bit.
1.jre-8u111-windows-x64 2.vlc-2.2.4-win64 I can not send files I ask you to find it from google.
num127 wrote:First of all, I want to thank you build a very good program I encourage you to develop it further.
[img][/img]
number 2 and 3 have been solve in the upcoming release cant you send an image of what the Thailand language looks like?
stevespaw wrote:vfxblend wrote:sorry for my silence, iv been busy rewriting the whole code in c# i am done now recording a tutorial for it now the new update includes:
1. Whole new Interface 2. Ability to trim in and out of a clip 3. Mute button for both displays 4. Ability Shuffle selected clips 5. Ability to Duplicate a clip 6. Adding Clips now appends after selected clip 7. Open dialog now supports search and displays thumbnails 8. New Column added for instant retime 9. New color scheme to identify TAGS, playing, Aired and Ready This sounds great, I look forward to trying it out, Just to make this thread work better for you, if you could make your announcements and information by just editing your first post with updated information. Great example is the UTC thread. http://forums.vmix.com/default.aspx?g=posts&t=6468 I look forward to seeing the info there and any tutorials etc. Thanks for your work on this it look great, Steve thank you steve for the insight
You have been a member since:: 11/28/2015(UTC) Posts: 3 Location: india
plz give new update link...
The top line is the correct language. The bottom line The display language is faulty num127 attached the following image(s):  1479026867783.jpg (23kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
ok, will look into the language The link for the update will surely be available later today thanks.
 3 users thanked vfxblend for this useful post.
When will this downloadable version be available?
Joined: 1/30/2016(UTC) Posts: 5 Location: Douala Cameroon
Good evening !!! This is a great job !!! i hope you will add the possibility to automatically removed aired items on vmix timeline. Also if we can create a group of tag.( ie grouptag1: overlay1+overlay2 are active , grouptag2: overlay2+overlay3 are active)
Regards
