brendanh
#1 Posted : Friday, July 8, 2016 9:51:57 PM(UTC)
brendanh
Hello! I'm having some difficulty figuring out if Vmix supports multiple inputs from the Decklink 4k Pro. It's supposed to have (According to the box) "2 X 12Gb/s SD/HD/2K/4K SDI INPUTS"
Since the lower tier Decklink says it only has one input, does this mean I can use 2 SDI cameras with the Decklink 4k Pro? I'm only seeing one Decklink input listed in Vmix.
The plugs on the back of the DeckLink 4k pro are labelled as input a and input b.
I am running Windows 7 and have the latest Blackmagic Desktop Video software installed.
Any help is appreciated. Thanks!
AElli
#2 Posted : Saturday, July 9, 2016 10:57:00 PM(UTC)
AElli
Usually with BMD the A B scenario is a feature called dual link for use with 3D stereo workflows.
Ie a left and a right video channel.
So I think Vmix is reporting correctly in you only have 1 single input / output and not 2 seperate usable video channels.
A.
roverradio
#3 Posted : Thursday, September 29, 2016 9:15:40 PM(UTC)
roverradio
I'm curious about this as well. It seems as if it SHOULD support 2 independent inputs and 2 independent outputs.
"SDI Video Input: 2 x 12Gb/s SD/HD/2K/4K. Supports single link and dual link 4:2:2/4:4:4."
"Ideal for both traditional 2D and high end 3D stereoscopic workflows, you get support for full resolution, deep color YUV and 12-bit RGB 4:4:4 images. DeckLink 4K Pro features two multi rate 12G-SDI inputs and outputs with support for 16 channels of embedded audio, along with a connection for reference input."
I need to get 8x input for 4K, and 4 of these would be great.
Did you ever get this working? Anyone else have experience with this card?
wild765
#4 Posted : Friday, November 4, 2016 1:18:09 AM(UTC)
wild765
You have been a member since:: 11/4/2016(UTC)
roverradio
Go into the BMD Setup program for the Decklinks, Select the card, and the at the bottom of the next screen should be a spot to setup the input. IE, it will say "SDI1 & SDI2" in a drop down with options of "SDI1" and "None". Choose "SDI1". Slide to the second input, and it should be set to "SDI2" (other option would be "None").
We have a "Duo 2", and this options makes the 4 inputs work as single units.
Siroki
#5 Posted : Friday, November 4, 2016 10:02:33 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
So this card can take simultaneously 2 input cameras?
How I red when have this one it can't be done ( I think on decklink 4k pro).. It can do only one input at time. So you can do A in B out or B in A out.
Maybe I am wrong
