Desktop Capture - Anyway to hide mouse?
Joined: 2/9/2013(UTC) Posts: 266 Location: Katy, Texas
When using the stand alone version of desktop capture, there is a setting to hide the cursor or mouse. When trying to capture a second screen on the vMix machine is there a similar setting to avoid capturing the movement of the mouse? I've looked and can't find anything.
Thanks Kelvin
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
un check show cursor in settings desmar attached the following image(s):  Capture0.PNG (7kb) downloaded 39 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
For the local desktop capture, there isn't currently a way to disable showing the cursor, but I will look at this for the next update.
Hi Kelvin,
The ability to turn off the cursor for local desktop capture is now in 17.0.0.107
Martin vMix
Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
admin wrote:Hi Kelvin,
Martin vMix Is there a checkbox for this somewhere? When I pick one of my local full displays, I see the cursor. If I pick a program window, no cursor. I can't seem to find a checkbox to capture it or not. Am I missing something obvious? (running 17.0.0.112) -Brian
