Kelvin
#1 Posted : Friday, August 12, 2016 11:57:56 PM(UTC)
Kelvin
When using the stand alone version of desktop capture, there is a setting to hide the cursor or mouse. When trying to capture a second screen on the vMix machine is there a similar setting to avoid capturing the movement of the mouse? I've looked and can't find anything.
Kelvin
desmar
#2 Posted : Saturday, August 13, 2016 12:08:21 AM(UTC)
desmar
Canada
un check show cursor in settings
desmar attached the following image(s):
#3 Posted : Saturday, August 13, 2016 12:31:37 AM(UTC)
For the local desktop capture, there isn't currently a way to disable showing the cursor, but I will look at this for the next update.
#4 Posted : Sunday, August 14, 2016 11:55:54 PM(UTC)
Hi Kelvin,
The ability to turn off the cursor for local desktop capture is now in 17.0.0.107
tesn
#5 Posted : Thursday, November 3, 2016 3:17:15 PM(UTC)
tesn
Was thanked: 13 time(s) in 9 post(s)
admin wrote:
Hi Kelvin,
Is there a checkbox for this somewhere? When I pick one of my local full displays, I see the cursor. If I pick a program window, no cursor. I can't seem to find a checkbox to capture it or not.
Am I missing something obvious?
(running 17.0.0.112)
-Brian
