My client wants the ability to delay a live feed to prevent profanity, bloopers or other undesirable material from making it to air. The delay needs to be about 30 seconds to allow the client time to react and decide if the show should be temporarily switched off and then back on again. Any suggestions on how this could be achieved?
Thanks, S
Squier wrote:My client wants the ability to delay a live feed to prevent profanity, bloopers or other undesirable material from making it to air. The delay needs to be about 30 seconds to allow the client time to react and decide if the show should be temporarily switched off and then back on again. Any suggestions on how this could be achieved?
Thanks, S
Setup a second vMix system on your LAN. Use that as the streaming machine. Turn on NDI output on your production machine and on the streaming machine add an NDI Input to ingest the stream. On the NDI input, select the gear icon to access the settings and choose Advanced. On the top left set the required delay. Close the settings window. Enjoy.
 1 user thanked ask for this useful post.
Thanks. I was expecting something quite complicated but that sounds quite straight forward. Cheers!
